HI all
I am trying to run a Brush DC motor at constant rpm. I am implementing a PID controller with a hall effect switch.
The code i am using to get the hall effect readings is from http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274834441
I am using the PID beta library for my PID controller.
The problem i am having is that while im tuning my PID controller following PID - Cookbook | Mbed
Somehow the hall switch code interferes with my PID loop. When the motor is away from the switch.. and the switch is giving an rpm reading of 0. The duty cycle jumps up like its supposed to... But as soon as i start getting readings on the hall sensor...even if they are below my setpoint.. the arduino stops sending the PWM signal. When the motor stops the sensor reads 0 rpm again and then pwm shoots up to high.. then when the hall sensor reads the rotation the pwm signal stops again.
This happens in a loop. What could be the problem? Also my rpm reading is not always accurate it varies by 60rpm. is there a way to set a range of acceptable values so that the chip doesnt constantly try to focus on 1 specific rpm readout value?
Here is the code given below:
// ArduECU version 0.01 alpha
// Compiled with Arduino v0018
// Thanks to the members of the arduino.cc forum for their assistance
// Many comments removed to fit sketch into forum posting box...
#include <PID_Beta6.h>
double Input, Output, Setpoint;
PID pid(&Input, &Output, &Setpoint, 6, 0, 0);
extern volatile unsigned long timer0_overflow_count; // Record the most recent timer ticks
volatile boolean ticks_valid; // Indicates a valid reading
volatile unsigned long ticks_per_rev; // Number of ticks counted in the current revolution
unsigned long msSinceRPMReading; // Number of mSec since the last rpm_sense (used to spot zero RPM)
float lastRPM, peakRPM; // Most recent RPM reading, and highest RPM recorded since last reset
const float __TICKS_TO_RPMS = 15e6; // Convert clock ticks to RPM by dividng ticks into this number
// The number will change if there are more magnets in an rpm
// (e.g. 2 magnets = 29296.875)
const unsigned int __WAIT_BEFORE_ZERO_RPM = 2000; // Number of mS to wait for an rpm_sense before assunming RPM = 0.
const int __REV_GAUGE_PIN = 3; // 100uA meter on this pin, with 50K current-limiting resistor
unsigned long msSinceSend; // mSec when the last data was sent to the serial port
const unsigned int __WAIT_BETWEEN_SENDS = 1000; // Number of mS to wait before sending a batch of data.
int outputPsuB = 10; // Timer1-B
int dutycycle = 85; //50% duty cycle
Serial.begin(9600); // Initialise serial comms.
pid.SetOutputLimits(0, 500);
Setpoint = 7300;
pid.SetMode(AUTO);
msSinceSend = millis(); // Data sent counter
attachInterrupt(0, rpm_sense, RISING); // RPM sense will cause an interrupt on pin2
msSinceRPMReading = 0; // If more than 2000 (i.e. 2 seconds),
// then RPMs can be assumed to be zero (< 15rpm
// at most, with a single magnet, no small IC
// can run that slowly).
lastRPM = 0; // Current RPM to zero
peakRPM = 0; // Max recorded RPM to zero
pinMode(__REV_GAUGE_PIN,OUTPUT); // Set pin 3 to be output
pinMode(outputPsuB, OUTPUT); // select Pin as ch-B
TCCR1A = B00100001; // PWM, Phase and frequency correct - change at OCR1A
TCCR1B = B10010; // prescaling by 8 the system clock
// FUNCTION: RPM-SENSE
// Called whenever the RPM sense signal rises. In my setup, the hall effect switch is normally
// high, goes low when a south pole is introduced to the sensor, and rises back to high as the
// magnet goes away. Thus, the RPM sense is called on the trailing edge of the magnet.
// Version Date By Comment
// 0.01a 26-May-2010 JAV Created (with an assist from BenF from the arduino.cc forum
void rpm_sense()
static unsigned long pre_count; // Last timer0_overflow_count value
unsigned long ticks_now; //
ticks_now = timer0_overflow_count; // Read the timer
byte t = TCNT0;
if ((TIFR0 & _BV(TOV0)) && (t<255))
ticks_now++;
ticks_now = (ticks_now << 8) + t;
if (pre_count == 0) { // First time around the loop?
pre_count = ticks_now; // Yes - set the precount, don't use this number.
ticks_per_rev = ticks_now - pre_count; // No - calculate the number of ticks...
pre_count = ticks_now; // ...reset the counter...
ticks_valid = true; // ...and flag the change up.
unsigned long thisMillis = millis(); // Read the time once
Input = lastRPM;
Output = dutycycle;
pid.Compute();
//Serial.print("dutycycle: ");
//Serial.println(dutycycle);
//Generation of PWM Signal
OCR1A = 500; // 122.0Hz at 8197us|140Hz at 7143us|2kHz at 500us
OCR1B = Output; // 99.9% DC at 8196|40% DC at 7071
// Calculate RPM
if (ticks_valid)
{ // Only come here if we have a valid RPM reading
unsigned long thisTicks;
noInterrupts();
thisTicks = ticks_per_rev;
ticks_valid = false;
interrupts();
lastRPM = __TICKS_TO_RPMS / thisTicks; // Convert ticks to RPMs
ticks_valid = false; // Reset the flag.
msSinceRPMReading = thisMillis; // Set the time we read the RPM.
if (lastRPM > peakRPM)
peakRPM = lastRPM; // New peak RPM
// No tick this loop - is it more than X seconds since the last one?
if (thisMillis - msSinceRPMReading > __WAIT_BEFORE_ZERO_RPM)
lastRPM = 0; // At least 2s since last RPM-sense, so assume zero RPMs
msSinceRPMReading = thisMillis; // Reset counter
// Is it time to send the data?
if (thisMillis < msSinceSend) // If thisMillis has recycled, reset it
if (thisMillis - msSinceSend > __WAIT_BETWEEN_SENDS)
Input = lastRPM;
//dutycycle = Output;
pid.Compute();
// Yes: Build the serial output...
// For now, send everything plaintext. Maybe compression would be a good thing, later down the line...
Serial.print("uECUv0.01|CurrentRPM: "); // Send ID - ditch this for something smaller
Serial.print(lastRPM); // Current RPMs
Serial.print("|"); // Field Separator
Serial.print(peakRPM); // Peak RPMs
Serial.print("|DutyCycle: "); // Field Separator
Serial.print(dutycycle); // Temperature #1 (water in)
Serial.print("|PIDOut: "); // Field Separator
Serial.print(Output); // Temperature #2 (water out)
Serial.print(0); // Temperature #3 (exhaust gas)
// Debugging
// Serial.print("|"); // Field Separator
// Serial.print(ticks_per_rev); // clock ticks in the last rpm
// That'll do for bnow
Serial.println(); // EOL.
msSinceSend = millis(); // Reset the timer
if (Serial.available()) {
char cmd = Serial.read();
if (char('R') == cmd) {
peakRPM=0;
Serial.flush();
// Set the RPM gauge value in real-time...
if (lastRPM < 1000) {
// Sub-1000 RPMs, map to between 0-255
analogWrite(__REV_GAUGE_PIN,map(lastRPM,0,1000,0,255));
// If RPMs > 1000, write 255 (=meter FSD); but we've got bigger problems if the RPMs ever get this high...
analogWrite(__REV_GAUGE_PIN,255);
Thank you all in advance for your help!!
