PID controller for High Switching frequency
Hi…
I am attaching one code below, please tell me whether it’ll work or not for generating PWM signal for 6o KHz switching frequency.
#include "Arduino.h"
#include <PID_v1.h>
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
  //initialize the variables we're linked to
  Input = analogRead(0);
  Setpoint = 100;
  TCCR0B = TCCR0B & 0b11111000 |0x01;
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
  myPID.Compute();
  analogWrite(5,Output);
No, analogRead takes at least 100 usec, so you can't get faster than 10 kHz with your code. Plus, count how much times does it takes to calculate PID, you may insert microseconds() arduino function before and after PID line. Example:
  time_start = micros();
 PID();
  time_sampl  = micros() - time_start;
As analogRead() is waiting >80% of its time until AD conversion is done a lot of CPU cycles are lost. you can improve quite a bit on the analogRead() by making it asynchronous. Not trivial but not too complicated either.
See some previous work here - http://forum.arduino.cc/index.php?topic=157381.msg1178912#msg1178912 -
I don’t think the problem calls for the analogRead() and PID algorithm to be performed at 60KHz, only that the analog output runs at that frequency. I’m not familiar enough with the hardware timers to know whether you’re configuring them correctly to achieve that but if you haven’t already read it I suggest you read Nick Gammon’s tutorials about changing the analog output frequency.
Hi…
If we’ll use our own code for PID controller for generating PWM signal instead of using PID library, then it’ll work or not.
Code is given below
double Setpt, Actual, Drive,Error,Integral,P,I,D,Last;
void setup(){
  Actual = analogRead(0);
  Setpt =20;
void loop(){
  Actual= analogRead(0);
   Setpt =20;
  Error = Setpt- Actual;
  if (abs(Error) < 0.1){ // prevent integral 'windup'
    Integral = Integral + Error; // accumulate the error integral
  else {
    Integral=0; // zero it if out of bounds
  P = Error*1; // calc proportional term kP=1
  I = Integral*4; // integral term kI=4
  D = (Last-Actual)*2; // derivative term kD=2
  Drive = P + I + D; // Total drive = P+I+D
  Drive = Drive*250; // scale Drive to be in the range 0-255
  if (abs(Drive)>255) {
    Drive=255;
  if (abs(Drive)<0){
    Drive=0;
 Last=Actual;
  analogWrite(5,Drive);
Switching frequency is 62.5 KHz.
Hi…
Code is given below
void setup(){
  Setpt =20;
void loop(){
   Setpt =20;
  else {
    Drive=255;
  if (abs(Drive)<0){
    Drive=0;
 Last=Actual;
If we'll use our own code for PID controller for generating PWM signal instead of using PID library, then it'll work or not
For what it's worth I agree, but do you have a question ?
Why bother? You're going to over-write it in a hundred microseconds or so.
ADI89:
it’ll work or not.
I can think of one way to find out.
I could n't get you PeterH
AWOL ,I could n't get you.
Why bother reading "Actual" in "setup()"? It'll get overwritten in "loop()".
K . Thank you :) So this code will work.
If you want to know whether it works, the most obvious way to find out is to test it.
I merged these two very similar threads.
may be a stupid question but I have one doubt in this code. analogRead(0) will give a value in 0-1024 ,but set point is a decimal value , how it’ll be possible?
#include <PID_v1.h>
  Setpoint = 100;
  //turn the PID on
  myPID.Compute();
Close, but no cigar.
The "int" returned by "analogRead()" will be promoted to a "double" in the assignment Input = analogRead(0);
