PID DC motor position by use Absolute encoder.
I have project to control motor position by use PID controller and have absolute encoder to feedback.
when i run my code. it not move to degree i want to move but just move back and forword between degree i want. i dont know wut i miss or mistake in side my code. Thank for helping :smiley:
Equipment
-Arduino mega 2560
-Absolut Encoder 12 bit
-Dc motor
-Drive motor
if you read and think it strange. i sorry I not strong in English language. :sweat_smile:
#include <PID_v1.h>//control position motor by serial monitor,feedback by ancoder
//Abosolute Encoder 12 Bit 4096
int CLK = 13; // Blu  Pin 10
int DO = 12; // Grn   Pin 11
int CSn = 11; // Ylw  Pin 12
// Drive motor
const int pwm = 2 ;//initializing pin 2 as pwm  orange
const int in_1 = 8 ;//turn right pin 8 gray
const int in_2 = 9 ;//turn left pin 9 green
//set PID
double kp = 2, ki = 0, kd = 0;
double input = 0, output = 0, setpoint = 0;
PID myPID(&input, &output, &setpoint, kp, ki, kd, DIRECT);
int Degree = 0;
  Serial.begin(9600);//text for start
  pinMode(CSn, OUTPUT);// Chip select
  pinMode(CLK, OUTPUT);// Serial clock
  pinMode(DO, INPUT_PULLUP);// Serial data IN/OUT
  pinMode(pwm,OUTPUT) ;   //we have to set PWM pin as output
  pinMode(in_1,OUTPUT) ;  //Logic pins are also set as output
  pinMode(in_2,OUTPUT) ;
  digitalWrite(CSn, HIGH);
  digitalWrite(CLK, HIGH);
  TCCR1B = TCCR1B & 0b11111000 | 1;
  myPID.SetMode(AUTOMATIC); //Autoset PID
  myPID.SetSampleTime(1);
  myPID.SetOutputLimits(-100, 100);  // max speed value can change later
  digitalWrite(in_1,HIGH) ;
  digitalWrite(in_2,HIGH) ;
  while (! Serial);
  Serial.println("In put your Angle");
if (Serial.available())
      int Angle = Serial.parseInt();
      setpoint = Angle;
    ReadEncoder();
    input = Degree;
    myPID.Compute();
     Serial.println(Degree); Serial.println(","); Serial.println(output);
     delay(100);
    pwmOut(output);
void pwmOut(int out) {
  if (out > 0) {
     digitalWrite(in_1,HIGH);//turn right
     digitalWrite(in_2,LOW) ;
     analogWrite(pwm,out) ;
  else {
       digitalWrite(in_1,LOW) ;//turn left
  }    analogWrite(pwm,out) ;
void ReadEncoder()
{  int Data = ReadSSI();
   Degree = map(Data, 0, 4095, 0, 359); //cange data to Degree
int ReadSSI(void)//read clk cs do from encoder
{ int i, dReading;
  char Resolution = 12;
  unsigned int bitStart = 0x0800;
  dReading = 0;
  digitalWrite(CSn, LOW);
  delayMicroseconds(5);
  digitalWrite(CLK, LOW);
  for (i = (Resolution - 1); i >= 0; i--)
  { digitalWrite(CLK, HIGH);
    if (digitalRead(DO)) dReading |= bitStart;
    bitStart = bitStart >> 1;
    if (i == 0)
  return dReading;
else {
  }    analogWrite(pwm,out) ;  //  is that } in the right place?
If you use autoformat (ctri-t or Tools, Auto Format) the program flow will be clearer.
groundFungus:
else {
Thank I just write new one it can change to angle I want but would like to put PID but I don t know where to put it
#include <PID_v1.h>
const int pwm = 2 ;  //initializing pin 2 as pwm
double kp = 20, ki = 0, kd = 0;
double pid_p = 0, pid_i = 0, pid_d = 0;
double E  = 0,sp = 180,lastE =0,pv = 0;
double elapsedTime, Time, timePrev;
int Degree = 0;
int now = 0;
int PID_value = 0;
    Time = millis();
       ReadEncoder();
                   sp = 180+Angle;
       pv = Degree;
       E = sp - pv;
       lastE = E;
       pid_p = kp*E;
       pid_i = ki*E;
       timePrev = Time;
       Time = millis();
       elapsedTime = (Time - timePrev)/ 1000;
        pid_d = kd*(E/elapsedTime);
          now = Degree - 180;
         PID_value =  pid_p + pid_i + pid_d;
        Serial.print( PID_value);   Serial.print(" ");   Serial.print(E);   Serial.print(" ");  Serial.println(now);
          if(E>0)      { if(E  = 0){
                                      digitalWrite(in_1,HIGH) ;digitalWrite(in_2,HIGH) ;
                                      analogWrite(pwm,100);
                         else      {
                                      digitalWrite(in_1,HIGH) ;digitalWrite(in_2,LOW) ;
                                      analogWrite(pwm,30) ;
          else if(E<0) { if(E  = 0){
                                       analogWrite(pwm,100) ;
                          else      {
                                       digitalWrite(in_1,LOW) ;digitalWrite(in_2,HIGH) ;
                                       analogWrite(pwm,30);
          else          {
                                         lastE = E;
void ReadEncoder()
{ int i, dReading;
  dReading = 0;
    if (i == 0)
  return dReading;
