I use the following code for a line-follower driven by two rear wheels and a castor wheel. The sensor array is a row of 8.
But the lMotorSpeed doesn't vary with the position of the line with respect to the sensor array. A black line on a white surface was used and black returns val_>500 and white val*<500._
Please help me find the fault. Kp Ki Kd values are not fully adjusted yet. ![]()
_```_
#define Kp 2
#define Ki 0.0004
#define Kd 1
#define MaxSpeed 255
#define baseSpeed 180
#define rMotor1 34
#define rMotor2 35
#define lMotor1 30
#define lMotor2 31
#define lMotorPWM 3
#define rMotorPWM 2
int rMotorSpeed,lMotorSpeed,error_value;
long sensors_average,integral;
int sensors_sum,position,proportional,derivative,last_proportional;
int set_point=13;
int val[8]={0};
int th=500;// less than th means W
void sensors_read(){
 val[0]=analogRead(A0);
 val[1]=analogRead(A1);
 val[2]=analogRead(A2);
 val[3]=analogRead(A3);
 val[4]=analogRead(A4);
 val[5]=analogRead(A5);
 val[6]=analogRead(A6);
 val[7]=analogRead(A7);
Â
 for(int i=0;i<8;i++)
  sensors_average+=val[i]i1000;
  sensors_sum+=int(val[i]);
 Â
Â
Â
Â
void pid_calc(){
  position=int(sensors_average/sensors_sum);
  proportional=position-set_point;
  integral=integral+proportional;
  derivative=proportional-last_proportional;
  last_proportional=proportional;
  //Serial.print(position); Serial.print(" || ");
  //delay(300);
 Â
  error_value = int(proportional * Kp + integral * Ki + derivative * Kd);
  //Serial.print(error_value);Serial.print("\n");
  //delay(300);
Â
Â
void calc_turn()
 Â
  rMotorSpeed=baseSpeed+error_value;
 Â
  lMotorSpeed=baseSpeed-error_value;
   Â
  if(rMotorSpeed>MaxSpeed)
   rMotorSpeed=MaxSpeed;
  if(lMotorSpeed>MaxSpeed)
   lMotorSpeed=MaxSpeed;
  if(rMotorSpeed<0)
   rMotorSpeed=0;
  if(lMotorSpeed<0)
   lMotorSpeed=0;
 Â
  Serial.print(rMotorSpeed); Serial.print(' ');
  Serial.print(lMotorSpeed);Serial.print("\n");
  //delay(300);
Â
void motor_drive(int rSpeed,int lSpeed)
  analogWrite(rMotorPWM,rSpeed);
  analogWrite(lMotorPWM,lSpeed);
  delay(50);
Â
 pinMode(lMotor1, OUTPUT);Â
 pinMode(lMotor2, OUTPUT);  Â
 pinMode(rMotor1, OUTPUT);Â
 pinMode(rMotor2, OUTPUT);
 digitalWrite(lMotor1,HIGH);
 digitalWrite(lMotor2,LOW);
 digitalWrite(rMotor2,HIGH);
 digitalWrite(rMotor1,LOW);
Â
 pinMode(rMotorPWM, OUTPUT);Â
 pinMode(lMotorPWM, OUTPUT);Â
Â
Â
 Â
 sensors_average=0;
 sensors_sum=0;Â
 sensors_read();
Â
 pid_calc();
 calc_turn();
 motor_drive(rMotorSpeed,lMotorSpeed);
Â
Â
Â
_```*_
AC_FOLLOWER_2_0.ino (3.37 KB)
