PID for Motor control.
So im looking to control motor speed for landing autonomously based on feedback from an ultrasonic sensor.
I recently came across using a PID Library.
However im not sure how to go about it.
Thanks.
Below is the example from the library
 * PID Basic Example
 * Reading analog input 0 to control analog PWM output 3
#include <PID_v1.h>
#define PIN_INPUT 0
#define PIN_OUTPUT 3
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
double Kp=2, Ki=5, Kd=1;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
  //initialize the variables we're linked to
  Input = analogRead(PIN_INPUT);
  Setpoint = 100;
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
  myPID.Compute();
  analogWrite(PIN_OUTPUT, Output);
Do i calculate the distance in cm and directly put that into the input variable with the Setpoint as 0 for landed?
LimeAy:
Landing what? Can you explain your project and existing hardware?
Power_Broker:
Apologies - im using an ultrasonic sensor to land a quadcopter drone by sending PWM signals according to a PID controller.
Existing hardware - drone esc attached to motors
Ultrasonic sensor
Arduino Nano board powered via battery.
Are you sure that a single PWM signal will be sufficient for all 4 motors of the quadcopter?
