PID identifiers of PMC Peripheral Clock registers
Hello,
i'm reading the samx3 's datasheet, and i want to know something. i read on page 563 : " To get PIDx, refer to identifiers as defined in the section “Peripheral Identifiers” in the product datasheet." about the PMC Peripheral Clock Status Register 0. Where can i find the section “Peripheral Identifiers”?
an other thing i don't understand is why they are 2 PMC Peripheral Clock registers, because they are 3 timers and each one have 3 channels. So if i want to enable the channel 2 of the TC2, i use PMC_PCER0 or PMC_PCER1 ?
thanks
The timer Counter naming may be confusing:
Timer Counter 0 channel 0 is TC0
Timer Counter 0 Channel 1 is TC1
Timer Counter 2 Channel 2 is TC8
To select the clock for a given TCx, refer to PID page 38 of Sam3x datasheet, I.e.:
PMC->PMC_PCER0 for TCx PID 27(TC0) to 31(TC4) and PMC->PMC_PCER1 for TCx PID 32(TC5) to 35(TC8).
An example sketch with TC8:
/*       Timer Counter 2 Channel 2, namely TC8, 1 MHz frequency   */
  pinMode(LED_BUILTIN, OUTPUT);
  tc_setup();
void tc_setup() {
  PMC->PMC_PCER1 |= PMC_PCER1_PID35;                      // TC8 power ON : Timer Counter 2 channel 2 IS TC8 - see page 38
  PIOD->PIO_PDR |= PIO_PDR_P7;                            // Set the pin to the peripheral
  PIOD->PIO_ABSR |= PIO_PD7B_TIOA8;                       // Peripheral type B
  TC2->TC_CHANNEL[2].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK1  // MCK/2 = 42 M Hz, clk on rising edge
                              | TC_CMR_WAVE               // Waveform mode
                              | TC_CMR_WAVSEL_UP_RC       // UP mode with automatic trigger on RC Compare
                              | TC_CMR_ACPA_CLEAR         // Clear TIOA2 on RA compare match
                              | TC_CMR_ACPC_SET;          // Set TIOA2 on RC compare match
  TC2->TC_CHANNEL[2].TC_RC = 42;  //<*********************  Frequency = (Mck/2)/TC_RC  Hz
  TC2->TC_CHANNEL[2].TC_RA = 41;  //<********************   Any Duty cycle in between 1 and TC_RC
  TC2->TC_CHANNEL[2].TC_IER = TC_IER_CPAS;
  NVIC_EnableIRQ(TC8_IRQn);
  TC2->TC_CHANNEL[2].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC2 counter and enable
void TC8_Handler() {
  static uint32_t Count;
  TC2->TC_CHANNEL[2].TC_SR;
if (Count++ == 1000000) {
  Count = 0;
  PIOB->PIO_ODSR ^= PIO_ODSR_P27;
thanks it helps a lot
