PID Library MISHAP!(Pls Help longTime problem)
Thanks! Mr.John, One more question I'm setting the setpoint of the PID value to the counts that are taken up by the encoder like 9 so I think when the PID sees the value counted isn;t 9 then it will strive to achieve that position by rotation forward or reverse to get hold to that position but mine isn;t working like that??
The following is the completed code:
#include <PID_v1.h>
#define encoder0PinA 2
#define encoder0PinB 3
volatile unsigned int encoder0Pos = 0;
// Motor control 1 is connected to the Digital PIN 5
const int MotorControlPin1 = 5;
// Motor control 2 is connected to the Digital PIN 6
const int MotorControlPin2 = 6;
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
  pinMode(encoder0PinA, INPUT);
  pinMode(encoder0PinB, INPUT);
  Setpoint = 4;
// encoder pin on interrupt 0 (pin 2)
  attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
  attachInterrupt(1, doEncoderB, CHANGE);
  myPID.SetMode(AUTOMATIC);
  Serial.begin (19200);
void loop(){
  Input = encoder0Pos;
  myPID.Compute();
  if (Output > 0)
     // Output is positive so set MotorControlPin2 (Direction) to HIGH
     digitalWrite(MotorControlPin2, HIGH);
     // When Direction is HIGH, a LOW on MotorControlPin1 (PWM Speed) causes the motor to run
     analogWrite(MotorControlPin1, 255 - constrain((int)Output, 0, 255));
    // Output is negative so set MotorControlPin2 (Direction) to LOW
    digitalWrite(MotorControlPin2, LOW);
     // When Direction is LOW, a HIGH on MotorControlPin1 (PWM Speed) causes the motor to run
     analogWrite(MotorControlPin1, constrain((int)-Output, 0, 255));
void doEncoderA(){
  // look for a low-to-high on channel A
  if (digitalRead(encoder0PinA) == HIGH) {
    // check channel B to see which way encoder is turning
    if (digitalRead(encoder0PinB) == LOW) {
      encoder0Pos = encoder0Pos + 1;         // CW
    else {
      encoder0Pos = encoder0Pos - 1;         // CCW
  else   // must be a high-to-low edge on channel A
    if (digitalRead(encoder0PinB) == HIGH) {
    else {
  Serial.println (encoder0Pos, DEC);
  // use for debugging - remember to comment out
void doEncoderB(){
  // look for a low-to-high on channel B
   // check channel A to see which way encoder is turning
    else {
  // Look for a high-to-low on channel B
  else {
    if (digitalRead(encoder0PinA) == LOW) {
    else {
