pid library unresponsive
pid library after installing error message "pid does not have name type" unzipped directly into documents/library and via desktop to no avail running windows 7 adrduino 1.0.4 any help/ thoughts gratefull
alex
You code ?
Did you stop and start the IDE after putting the PD library folder in documents/arduino/libraries ?
morning
yes unfortunately i have tried every combination possible to no avail am not good enough to understand c /h code imagine that is where problem exists
alex
No you haven't, otherwise it would work
Where, exactly, have you put the PID library folder ?
Have you stopped and started the IDE (all instances) since installing the library ?
Does the sample code compile OK ?
POST YOUR CODE
thats a fair assumption code is download from github for arduino pid
Answers ?
I've been using the PID library without any problems. Well, not that sort, anyway.
How to use this forum
