PID Library
Hi, I'm doing a project where I need to use the PID library.
This is my first time I am working with PIDs and I can't quite understand the terminologies used.
The PID will control a heater to heat up a surface to a pre-setted temperature with a pre-determined ramp rate or rate of climb.
In the PID function, where can I input the rate of climb of the temperature ?
You can't. You CAN change the setpoint, at the rate of climb that you want.
