PID Line follower QTR-A
Hi, i am making a line follower robot using arduino nano, pololu qtr8a sensor and tb6612fng dual motor driver.
This is my code:
#include <QTRSensors.h>
#define NUM_SENSORS 8 // number of sensors used
#define TIMEOUT 4 // waits for 2500 microseconds for sensor outputs to go low
#define EMITTER_PIN 13 // emitter is controlled by digital pin 13
QTRSensors qtra;
const uint8_t SensorCount = 8;
uint16_t sensorValues[SensorCount];
int IndicatorLED = 13;
//Motor 1
int pinAIN1 = 6; //Direction
int pinAIN2 = 7; //Direction
int pinPWMA = 5; //Speed
//Motor 2
int pinBIN1 = 8; //Direction
int pinBIN2 = 9; //Direction
int pinPWMB = 10; //Speed
//Standby
int pinSTBY = 12;
int position = 0;
int error = 0;
int m1Speed = 0;
int m2Speed = 0;
int motorSpeed = 0;
unsigned long previousMillis = 0; // time keeping function
int BlinkTime = 300; // blink time
int CycleTime = 1; // used to call for a blink toggle
int BlinkCycle = 1; // used to alternate the LED on and off
///////////////////////PID TUNING//////////////
int lastError = 0;
float KP = 0;
float KD = 0;
int M1 = 50; //base motor speeds
int M2 = 50; //base motor speeds
int M1max = 50; //max motor speeds
int M2max = 50; //max motor speeds
int M1min = 0; //min motor speeds
int M2min = 0; //min motor speeds
//Constants to help remember the parameters
static boolean turnCW = 0; //for motorDrive function
static boolean turnCCW = 1; //for motorDrive function
static boolean motor1 = 0; //for motorDrive, motorStop, motorBrake functions
static boolean motor2 = 1; //for motorDrive, motorStop, motorBrake functions
  qtra.setTypeAnalog();
  qtra.setSensorPins((const uint8_t[]) {A2, A4, A6, A7, A1, A0, A5, A3}, SensorCount);
  qtra.setEmitterPin(13);
  //Set the PIN Modes
  pinMode(IndicatorLED, OUTPUT);
  digitalWrite(IndicatorLED, HIGH);
  pinMode(pinPWMA, OUTPUT);
  pinMode(pinAIN1, OUTPUT);
  pinMode(pinAIN2, OUTPUT);
  pinMode(pinPWMB, OUTPUT);
  pinMode(pinBIN1, OUTPUT);
  pinMode(pinBIN2, OUTPUT);
  pinMode(pinSTBY, OUTPUT);
  for (int i = 0; i < 400; i++) // make the calibration take about 10 seconds
    TimeCheck();
    delay(5);
    qtra.calibrate(); // reads all sensors 10 times at 2500 us per read (i.e. ~25 ms per call)
  TimeCheck(); //Check to see if it is time to blink the LED
  uint16_t position = qtra.readLineBlack(sensorValues);
  // compute our "error" from the line position
  // error is zero when the middle sensor is over the line,
  error = position - 3500; /// using an 8 sensor array targeting middle of position 4 to 5
  // set the motor speed based on proportional and derivative PID terms
  motorSpeed = KP * error + KD * (error - lastError);
  lastError = error;
  /////////CHANGE THE - OR + BELOW DEPENDING ON HOW YOUR DRIVER WORKS
  m1Speed = M1 - motorSpeed; // M1 and M2 are base motor speeds.
  m2Speed = M2 + motorSpeed;
  if (m1Speed < M1min) //keep speeds to 0 or above
    m1Speed = M1min;
  if (m2Speed < M2min) m2Speed = M2min; if (m1Speed > M1max) //maximum allowed value
    m1Speed = M1max;
  if (m2Speed > M2max) //maximum allowed value
    m2Speed = M2max;
  // set motor speeds using the two motor speed variables above 255
  forward(); // run the motors based on error information
//////////////////////FORWARD////////
//Drive both motors CW, full speed
void forward()
  TimeCheck();
  motorDrive(motor1, turnCW, m1Speed);
  motorDrive(motor2, turnCW, m2Speed);
/* //Apply Brakes, then into Standby
  motorBrake(motor1);
  motorBrake(motor2);
  motorsStandby(); */
void TimeCheck() {
  if (currentMillis - previousMillis > BlinkTime) {
    // save the last time you blinked the LED
    BlinkIt();
void motorDrive(boolean motorNumber, boolean motorDirection, int motorSpeed)
    This Drives a specified motor, in a specific direction, at a specified speed:
    - motorNumber: motor1 or motor2 ---> Motor 1 or Motor 2
    - motorDirection: turnCW or turnCCW ---> clockwise or counter-clockwise
    - motorSpeed: 0 to 255 ---> 0 = stop / 255 = fast
  boolean pinIn1; //Relates to AIN1 or BIN1 (depending on the motor number specified)
  //Specify the Direction to turn the motor
  //Clockwise: AIN1/BIN1 = HIGH and AIN2/BIN2 = LOW
  //Counter-Clockwise: AIN1/BIN1 = LOW and AIN2/BIN2 = HIGH
  if (motorDirection == turnCW)
    pinIn1 = HIGH;
    pinIn1 = LOW;
  //Select the motor to turn, and set the direction and the speed
  if (motorNumber == motor1)
    digitalWrite(pinAIN1, pinIn1);
    digitalWrite(pinAIN2, !pinIn1); //This is the opposite of the AIN1
    analogWrite(pinPWMA, motorSpeed);
    digitalWrite(pinBIN1, pinIn1);
    digitalWrite(pinBIN2, !pinIn1); //This is the opposite of the BIN1
    analogWrite(pinPWMB, motorSpeed);
  //Finally , make sure STBY is disabled - pull it HIGH
  digitalWrite(pinSTBY, HIGH);
void motorBrake(boolean motorNumber)
    This "Short Brake"s the specified motor, by setting speed to zero
    analogWrite(pinPWMA, 0);
    analogWrite(pinPWMB, 0);
void motorStop(boolean motorNumber)
    This stops the specified motor by setting both IN pins to LOW
  if (motorNumber == motor1) {
    digitalWrite(pinAIN1, LOW);
    digitalWrite(pinAIN2, LOW);
    digitalWrite(pinBIN1, LOW);
    digitalWrite(pinBIN2, LOW);
void BlinkIt() {
  if (BlinkCycle == 1) {
    //Led On
  if (BlinkCycle == 2) {
    //Led Off
    digitalWrite(IndicatorLED, LOW);
    BlinkCycle = 0; // reset BlinkCycle
  BlinkCycle++; // Set BlinkCycle to second mode
i’m using a white course with a black line and after the calibration this my reading for the 8 sensors.
118 115 116 122 116 115 116 115
978 978 978 978 978 978 971 978
All the robot does is driving fast in circles.
so what do you think the problem?
Thanks for your help
If the robot moves in circles, one motor is rotating too slowly, or in the wrong direction.
jremington:
Thanks for your replay
i try the motors only and found the direction is the same for the two motors with the same speed.
But are the code steps is sound good?
Check whether the wheels are moving at the proper speed and direction.
jremington:
I checked the movement of the wheels and i don't have a problem with it the direction and speed similar to each , when i change the statues of line follower sensor there is no change in the wheel movement it still move in the same circle as if there was no change in the reading of the sensors.
Add some serial prints so you can see what speed you’re setting for each motor.
