PID (maybe) has its own life.
I am having some rather weird outputs from my Arduino. I am using PID and everything seems to be going fine but once in a while the system will output either max-output (255) or min-output (0) i dont know why! Has anyone else had problems of that sort with the PID library? i am trying to control the position of one motor with a Pot, the motor also has a pot connected to it to get a servo-like application.
The output to serial will give it off like this:
SteerPot: 577  wheelPot: 593 error: -20.00  Output: 23.58
 P: 1.28  I: 0.00  D: 0.00
SteerPot: 576  wheelPot: 593 error: -20.00  Output: 23.58
SteerPot: 577  wheelPot: 593 error: -20.20  Output: 23.58
 P: 1.29  I: 0.00  D: 0.00
SteerPot: 576  wheelPot: 593 error: -19.40  Output: 23.58
SteerPot: 578  wheelPot: 593 error: -21.60  Output: 23.58
SteerPot: 577  wheelPot: 593 error: -20.00  Output: 0.00
SteerPot: 576  wheelPot: 593 error: -17.80  Output: 0.00
SteerPot: 577  wheelPot: 593 error: -19.40  Output: 0.00
SteerPot: 577  wheelPot: 593 error: -19.20  Output: 0.00
SteerPot: 576  wheelPot: 593 error: -19.20  Output: 24.58
SteerPot: 577  wheelPot: 593 error: -19.40  Output: 24.58
SteerPot: 577  wheelPot: 593 error: -19.80  Output: 24.58
SteerPot: 578  wheelPot: 593 error: -19.80  Output: 24.58
Or like this:
SteerPot: 498  wheelPot: 486 error: 12.60  Output: 18.01
SteerPot: 498  wheelPot: 487 error: 12.80  Output: 18.01
SteerPot: 498  wheelPot: 487 error: 13.20  Output: 18.01
SteerPot: 497  wheelPot: 486 error: 13.20  Output: 18.01
SteerPot: 498  wheelPot: 487 error: 13.00  Output: 18.01
SteerPot: 498  wheelPot: 486 error: 13.60  Output: 18.01
SteerPot: 498  wheelPot: 486 error: 12.00  Output: 100.00
SteerPot: 497  wheelPot: 485 error: 16.20  Output: 100.00
SteerPot: 495  wheelPot: 480 error: 14.20  Output: 100.00
SteerPot: 488  wheelPot: 481 error: 13.00  Output: 100.00
SteerPot: 477  wheelPot: 477 error: 3.80  Output: 100.00
SteerPot: 464  wheelPot: 478 error: -6.40  Output: 100.00
SteerPot: 450  wheelPot: 473 error: -19.80  Output: 100.00
SteerPot: 438  wheelPot: 474 error: -37.80  Output: 57.94
SteerPot: 429  wheelPot: 476 error: -49.60  Output: 57.94
SteerPot: 426  wheelPot: 473 error: -57.60  Output: 57.94
If i run my feedback loop (serial connection) faster i see that the output of max/min will almost always come several times at a time. I cant seem to find any consistency in the wrong output.
I am taking the average of several readings to minimize jitter, dont know what else to do. Maybe i am using the PID library wrong?
Any advice would be great.
THX
And the Code
#include <PID_v1.h>
// Define input/output pins
const int steerPot = A3;
const int wheelPot = A1;
const int outputPin = 3;
const int directionPin = 2;
const int KpPin = A5;  //PID-reg*****************
const int KiPin = A4 ;
const int KdPin = A2;
// Define variables
int steerPos;    // position of steeringwheel
int wheelPos;    // position of wheels
double error;    //error between wheelPot and steerPot
double avgInput;    //Calculated average input
double avgSetpoint;    //Calculated average setpoint
double Setpoint, Input, Output; // PID variables
float Kp;  //PID-reg***************
float Ki;
float Kd;
// Define changeble values
double readings = 5;    //Amount of readings the averege setpoint,input is calculated on
byte outputMax = 100;    //Max output to motor (PWM)
const byte errorMax = 2;  // Max error between input/setpoint before action is taken
const int steerUL = (1023-175);    //Upper limit for pot
const int steerLL = 175;    //Lower limit for pot
// Major timer, lets user adjust how often the major loop (read pots and take action) should run
unsigned long previousMillis = 0UL;
unsigned long inputinterval = 25UL; // Time between main-loop run
// Serial output to console
unsigned long serialMillis = 0UL; // store timer current value, and start offset
unsigned long serialFeedbackMillis = 20UL;  //Time between sending feedback to serial
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, 1 ,0 ,0, DIRECT);
  TCCR2B = TCCR2B & 0b11111000 | 0x02;  // Timer 2: PWM 3 & 11 @ 3906,25 Hz
  pinMode(steerPot, INPUT);                 //Not needed if analogRead is used.
  pinMode(wheelPot, INPUT);
  pinMode(outputPin, OUTPUT);
  pinMode(directionPin, OUTPUT);
  pinMode(Kp, INPUT);    //PID-reg******************
  pinMode(Ki, INPUT);
  pinMode(Kd, INPUT);
  //initialize the variables we're linked to
  Input = analogRead(steerPot);
  Setpoint = analogRead(wheelPot);
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
  myPID.SetOutputLimits(0, outputMax);  //Limits the output
  myPID.SetSampleTime(200); // Determines how often the PID algorithm evaluates (default = 200)
  // current times since startup
  if(currentMillis - previousMillis > inputinterval) {  //Checks if its time to run the master loop
    previousMillis += inputinterval;  // if its time, it ads one interuptinterval for the next interval
  // reads the 3 pots and updates the Kp,Ki,Kd values
    Kp = analogRead(KpPin) / 100.0;  // Values from 0.0 to 10.23
    Ki = analogRead(KiPin) / 1000.0;  // Values from 0.0 to 1.023
    Kd = analogRead(KdPin) / 1000.0;  // Values from 0.0 to 1.023
    myPID.SetTunings(Kp, Ki, Kd);
     /* Kp = analogRead(KpPin); // reads the 3 pots and updates the Kp,Ki,Kd values
    Ki = analogRead(KiPin);
    Kd = analogRead(KdPin);
    myPID.SetTunings(analogRead(KpPin)/100, analogRead(KiPin)/1000, analogRead(KdPin)/1000);
    error = getError();
    if(error >= errorMax ) {
      TurnR();
    else if (error <= -errorMax)  {
      TurnL();
    else {
      digitalWrite(3, LOW);
  if(currentMillis - serialMillis > serialFeedbackMillis) { //Checks if its time to run the master loop
    serialMillis += serialFeedbackMillis; // if its time to print, it ads one interuptinterval for the next interval
    Cprint();
void TurnR() {
  if (analogRead(steerPot) < steerLL) {  // To stop the pot from overturning
    analogWrite(outputPin, 0);
  else {
    Setpoint = getSetpoint()*-1;
    Input = getInput()*-1;
    myPID.Compute();
    //Output = abs(Output);
    digitalWrite(directionPin, HIGH);
    analogWrite(outputPin, Output);
void TurnL() {
  if (analogRead(steerPot) > steerUL) {  // To stop the pot from overturning
  else {
    Setpoint = getSetpoint();   // If the pot is within the limits, the output is generated and sent to the motorboard
    Input = getInput();
    myPID.Compute();
    digitalWrite(directionPin, LOW);
double getError(){
  double wheelPos = getSetpoint();
  double steerPos = getInput();
  error = (steerPos-wheelPos);
  return error;
double getSetpoint() {
  long sum;
  long avg;
  for (int i = 0; i <= readings; i++) {
    sum += analogRead(wheelPot);
    //delay(1);
  avgSetpoint = sum/readings;
  sum = 0;
  return avgSetpoint;
double getInput() {
  long sum;
  long avg;
    sum += analogRead(steerPot);
    delay(1);
  avgInput = sum/readings;
  sum = 0;
  return avgInput;
void Cprint() {
  Serial.write("SteerPot: ");
  Serial.print(analogRead(steerPot));
  Serial.write("  wheelPot: ");
  Serial.print(analogRead(wheelPot));
  Serial.write(" error: ");
  Serial.print(error);
    Serial.write("  Output: ");
  Serial.println(Output);
  Serial.print(" P: ");
  Serial.print(Kp);
  Serial.print("  I: ");
  Serial.print(Ki );
  Serial.print("  D: ");
  Serial.println(Kd);
It might help to print the value of your input variable as well in your cprint routine. As it is, I can't make sense of the numbers. Since you have the posts set to make Ki and Kd zero, it might also help for debugging purposes to set them that way in the code, just in case there's some small fractional part in either of them.
