PID Motor Encoder
Good Evening,
I've been trying to adapt my PID motor controller code to start only when signalled by a bluetooth character. Currently, the PID controller relies on each loop iteration and rotates a motor cw for 1m in 10 secs to a predetermined target at 0.1m/s and then ccw at the same speed to 0m and looped.
Instead of relying on the loop, I'm trying to signal the sequence to start but no matter what I try I cannot find a solution. If I start the sequence after the running for say 5 secs, my motor will only rotate cw for 5 secs then on to ccw for 10 before looping correctly.
Can anyone suggest any changes I can make to my code (below) which would allow the sequence to start when signalled by the bluetooth character.
#include <util/atomic.h>
#define ENCA 2 // YELLOW
#define ENCB 3 // WHITE
#define IN2 9
#define IN1 10
char getstr;
int pos = 0;
volatile int posi = 0;
long prevT = 0;
long currT = 0;
float eprev = 0;
float eintegral = 0;
float deltaT;
float t;
// targets
float target_f = 0;
long target = 0;
float velocity; // m/s
void setTarget(float t, float deltat) {
  float positionChange = 0;
  float pulsesPerTurn = 4 * 131;
  float pulsesPerMeter = pulsesPerTurn * 18.85;
  t = fmod(t, 20); // time is in seconds
  if (t < 10) {
    positionChange = velocity * deltat * pulsesPerMeter;
  else if (t < 20) {
    positionChange = -velocity * deltat * pulsesPerMeter;
  target_f = target_f + positionChange;
  target = (long) target_f;
  pinMode(ENCA, INPUT_PULLUP);
  pinMode(ENCB, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(ENCA), readEncoder, RISING);
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  checkForMessage();
  // time difference
  currT = micros();
  deltaT = ((float) (currT - prevT)) / ( 1.0e6 );
  prevT = currT;
  // PID constants
  float kp = 0.5;
  float kd = 0.25;
  float ki = 0.0;
  setTarget(currT / 1.0e6, deltaT);
  ATOMIC_BLOCK(ATOMIC_RESTORESTATE) {
    pos = posi;
  // error
  int e = pos - target;
  // derivative
  float dedt = (e - eprev) / (deltaT);
  // integral
  eintegral = eintegral + e * deltaT;
  // control signal
  float u = kp * e + kd * dedt + ki * eintegral;
  // motor power
  float pwr = fabs(u);
  if ( pwr > 255 ) {
    pwr = 255;
  // motor direction
  int dir = 1;
  if (u < 0) {
    dir = -1;
  // signal the motor
  setMotor(dir, pwr, IN1, IN2);
  // store previous error
  eprev = e;
void setMotor(int dir, int pwmVal, int in1, int in2) {
  if (dir == 1) {
    digitalWrite(in2, LOW);
    analogWrite(in1, pwmVal);
  else if (dir == -1) {
    digitalWrite(in1, LOW);
    analogWrite(in2, pwmVal);
  else {
void readEncoder() {
  int b = digitalRead(ENCB);
  if (b > 0) {
    posi++;
  else {
    posi--;
void checkForMessage() {
  if (Serial.available()) {
    getstr = Serial.read();
  if (getstr == 'a') {
    velocity = 0.1; // m/s
What have you tried? There is nothing in the current code that looks like an attempt.
A state machine might be a good choice for this project, where checkForMessage() changes the state, and the loop function executes the commanded actions.
