PID not fully functioning
I am trying to control the position of the output shaft of a motor (pololu item#1447) using PID. As of now it works correctly until the input reaches the setpoint. In this case I have the Setpoint=2100 which, with the way the encoder code is written translates to pi revolutions (180 degrees) of the output shaft. Anyways. The problem is that when the Input >=Setpoint, Output=0.
Hardware/wiring follows code
My Code:
#include <PID_v1.h>
#define encoder0PinA  2
#define encoder0PinB  4
volatile long int encoder0Pos = 0;
double Setpoint, Input, Output;
PID myPID(&Input, &Output, &Setpoint,2,0,0,DIRECT);
int error;
int M1DIR=6;
  pinMode(encoder0PinA, INPUT);
  digitalWrite(encoder0PinA, HIGH);       // turn on pullup resistor
  pinMode(encoder0PinB, INPUT);
  digitalWrite(encoder0PinB, HIGH);       // turn on pullup resistor
  attachInterrupt(0, doEncoder, CHANGE);  // encoder pin on interrupt 0 - pin 2
  Serial.begin (9600);
  Serial.println("start");       // a personal quirk
  Input =encoder0Pos;
  Setpoint = 2100;
  myPID.SetMode(AUTOMATIC);
void loop(){
  Input =encoder0Pos;
  error=Setpoint-encoder0Pos;
  if(error<=0)
    digitalWrite (M1DIR,HIGH);
  if(error>0)
    digitalWrite (M1DIR,LOW);
  myPID.Compute();
  analogWrite(5,Output);
  Serial.println(Output,DEC);
// do some stuff here - the joy of interrupts is that they take care of themselves
void doEncoder() {
  /* If pinA and pinB are both high or both low, it is spinning
   * forward. If they're different, it's going backward.
   * For more information on speeding up this process, see
   * [Reference/PortManipulation], specifically the PIND register.
  if (digitalRead(encoder0PinA) == digitalRead(encoder0PinB)) {
    encoder0Pos++;
    encoder0Pos--;
I actually figured it out after I posted. I guess thats all it took for me to realize what was wrong. Thanks anyways, this is a great forum, with so much information. Thank you Arduino!
But, I’m not going to share…
sorry…it’s still not to where i need to be but I’m getting there. here’s my code now…
#include <PID_v1.h>
double Kp=0.1;
double Ki=0;
double Kd=0;
PID myPID(&Input, &Output, &Setpoint,Kp,Ki,Kd,DIRECT);
PID PID2(&Input, &Output, &Setpoint,Kp,Ki,Kd,REVERSE);
int error;
int M1DIR=6;
  Input =encoder0Pos;
  Setpoint = (-1800*2);
  PID2.SetMode(AUTOMATIC);
void loop(){
  Input =encoder0Pos;
  if(error<0)
    PID2.Compute();
    /*if (Output<20)
      Output=20;
      if (Output<17)
        Output=0;
  if(error>0)
    myPID.Compute();
    /*if (Output<20)
      Output=20;
      if (Output<17)
        Output=0;
void doEncoder() {
    encoder0Pos++;
    encoder0Pos--;
I need to work on PWM offset…the motor won’t turn at PWM values under around 25, so I need the PWM range linearly from 25 to 255 rather than 0 to 255.
The PID library has commands to set output limits both low and high for that kind of situation, it effectively clamps the output value between two values you set. You shouldn't try or have to do it in your code for every output command you process.
