Hi, the following code is written by electronoobs.com, i dont understand how he got the number 150 on line 67.
For example, the kp value is given as 8 on line 29 and the set point is 21 on line 32. If you calculate the distance_error given on line 52, it can have a value from -21 to +21 and with this if you calculate PID_p on line 53,the value would be from -168 to +168. So even with just kp value, the PID total would be more than 150 or less than -150. So how did he come up with the number 150?? ![]()
/* PID balance code with ping pong ball and distance sensor sharp 2y0a21
* by ELECTRONOOBS: https://www.youtube.com/channel/UCjiVhIvGmRZixSzupD0sS9Q
* Tutorial: http://electronoobs.com/eng_arduino_tut100.php
* Code: http://electronoobs.com/eng_arduino_tut100_code1.php
* Scheamtic: http://electronoobs.com/eng_arduino_tut100_sch1.php
* 3D parts: http://electronoobs.com/eng_arduino_tut100_stl1.php
#include <Wire.h>
#include <Servo.h>
///////////////////////Inputs/outputs///////////////////////
int Analog_in = A0;
Servo myservo; // create servo object to control a servo, later attatched to D9
////////////////////////Variables///////////////////////
int Read = 0;
float distance = 0.0;
float elapsedTime, time, timePrev; //Variables for time control
float distance_previous_error, distance_error;
int period = 50; //Refresh rate period of the loop is 50ms
///////////////////PID constants///////////////////////
float kp=8; //Mine was 8
float ki=0.2; //Mine was 0.2
float kd=3100; //Mine was 3100
float distance_setpoint = 21; //Should be the distance from sensor to the middle of the bar in mm
float PID_p, PID_i, PID_d, PID_total;
//analogReference(EXTERNAL);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.write(125); //Put the servco at angle 125, so the balance is in the middle
pinMode(Analog_in,INPUT);
time = millis();
if (millis() > time+period)
time = millis();
distance = get_dist(100);
distance_error = distance_setpoint - distance;
PID_p = kp * distance_error;
float dist_diference = distance_error - distance_previous_error;
PID_d = kd*((distance_error - distance_previous_error)/period);
if(-3 < distance_error && distance_error < 3)
PID_i = PID_i + (ki * distance_error);
PID_i = 0;
PID_total = PID_p + PID_i + PID_d;
PID_total = map(PID_total, -150, 150, 0, 150);
if(PID_total < 20){PID_total = 20;}
if(PID_total > 160) {PID_total = 160; }
myservo.write(PID_total+30);
distance_previous_error = distance_error;
float get_dist(int n)
long sum=0;
for(int i=0;i<n;i++)
sum=sum+analogRead(Analog_in);
float adc=sum/n;
//float volts = analogRead(adc)*0.0048828125; // value from sensor * (5/1024)
//float volts = sum*0.003222656; // value from sensor * (3.3/1024) EXTERNAL analog refference
float distance_cm = 17569.7 * pow(adc, -1.2062);
//float distance_cm = 13*pow(volts, -1);
return(distance_cm);
