Good evening,
i come to you about a problem that makes me crazy !!!
I have arduino Mega with CAN Bus Shield on top and PID to calculate PWM (Speed) according to PID Calculation,
#include <PID_v1.h>
//Define Variables for PID calculation
double Output;
//PID Parameters
double aggKp=4;
double aggKi=0.2;
double aggKd=1;
double consKp=1;
double consKi=0.05;
double consKd=0.25;
unsigned int PID_Gap = 5; // PID Parameter to setup between Aggressive and Conservative parameters (distance from Speed_Value and Idle_Speed)
// PINOUT Description
#define EVP_FWD_PIN 14 // EVP Pin for FWD Direction (RED Wire)
double Speed_Value = 0; // Variable to store Truck Speed (Value X100)
unsigned int Min_EVP = 50; // Minimum Prop.valve open sent to Danfoss Plus 1
unsigned int Max_EVP = 255; // Maximum Prop.valve open sent to Danfoss Plus 1
double Target_Speed = 0; // Target Speed to reach during Decel function
int Ratio = 0; // Ratio to calculate Target of PID
double Ratio_PID = 0;
PID myPID(&Speed_Value, &Output, &Target_Speed, consKp, consKi, consKd, DIRECT);
Serial.begin(115200); // Serial connexion
myPID.SetMode(AUTOMATIC); // Turn PID ON
myPID.SetOutputLimits(Min_EVP, Max_EVP);
void PID_Compute(unsigned int Target_Speed)
double gap = abs(Target_Speed - Speed_Value); //distance away from setpoint
Serial.print ("PID Gap : "); Serial.println (gap);
if (Debug){Serial.print ("PID Gap : "); Serial.println (gap);}
if (gap < PID_Gap)
//if (Debug == 1) {Serial.println ("Conservative PID");}
myPID.SetTunings(consKp, consKi, consKd);
Serial.println ("Aggressive PID");
//if (Debug == 1) {Serial.println ("Aggressive PID");}
myPID.SetTunings(aggKp, aggKi, aggKd);
//CAN_Receive();
Serial.println ("PID BEFORE: ");
Serial.println(Target_Speed);
Serial.println(Speed_Value);
Serial.println(Output);
myPID.Compute();
Serial.println ("PID AFTER: ");
Serial.print ("Output: "); Serial.println (Output);
void FWD_Fast ()
analogWrite (EVP_FWD_PIN, Max_EVP);
analogWrite (EVP_REV_PIN, 0);
void REV_Fast ()
analogWrite (EVP_REV_PIN, Max_EVP);
analogWrite (EVP_FWD_PIN, 0);
void CAN_Receive ()
Ratio_PID = Ratio;
if (FWD_IN)
PID_Compute(Speed_Target);
Serial.print ("Run FWD PWM : "); Serial.println (Output);
analogWrite (EVP_FWD_PIN, Output);
Sorry, but i have clean the code, possible to have discrepencies.
Output of my PID is always 0,
Serial datas:
PID BEFORE:
0
0.00
50.00
PID AFTER:
0
0.00
50.00
Output: 50.00
Run FWD PWM : 50.00
Ratio: 1
PID Gap : 1.00
Conservative PID
PID BEFORE:
1
0.00
50.00
PID AFTER:
1
0.00
50.00
Output: 50.00
Run FWD PWM : 50.00
Ratio: 8
PID Gap : 8.00
Aggressive PID
PID BEFORE:
8
0.00
50.00
PID AFTER:
8
0.00
50.00
Output: 50.00
Run FWD PWM : 50.00
Ratio: 16
PID Gap : 16.00
Aggressive PID
PID BEFORE:
16
0.00
50.00
PID AFTER:
16
0.00
50.00
Output: 50.00
i tried to monitor Values before and after myPID.compute (), remain the same.
Please do you have any idea about the issue ???
Thanks for help
