Hi guys,
For a project I use a mosfet and a PWM signal to control voltage over a train (by using a different duty cycle I can change the resistance of the mosfet -> different voltage).
But my code doesn't seem to work, it only gives 0 as output.
#include <PID_v1.h>
const int SpanningTreinLezer= A0;
const int MosfetPin = 6;
const int WensSpanningLezer = A2;
double alpha;
double Kp=-5, Ki=0.5, Kd=0;
double WerkelijkeTreinspanning;
double WensTreinspanning;
PID myPID(&WerkelijkeTreinspanning,&alpha,&WensTreinspanning,Kp,Ki,Kd,DIRECT); //Normally this should attain voltage we want in 6sec
int PIDtijd = -6000;
pinMode(MosfetPin,OUTPUT);
myPID.SetMode(AUTOMATIC);
Serial.begin(19200);
double WerkelijkeTreinspanning = analogRead(SpanningTreinLezer)*20.0/1023.0; // Voltage that the train has on the moment.
int beta;
double WensTreinspanning = 4+analogRead(WensSpanningLezer)*5/1023.0; //Voltage we want the train to have
if (WerkelijkeTreinspanning<4 && (millis()-PIDtijd)>6000)) {
analogWrite(MosfetPin,beta);
if (WerkelijkeTreinspanning >4 && (millis()-PIDtijd)>6000) { // We give PID 6secs to calculate
PIDtijd = millis();
myPID.Compute(); // This should compute alpha but only gives 0!!
int beta = alpha*255;
Serial.println(alpha);
The PID only gives alpha=0, and I don't know what's wrong.
I will also add system. Btw I can change wenstreinspanning (by turning a potentiometer).
Here's the circuit
PI, I gave a Kc and Ti not equal to 0 and Td=0.
I use the *255, because the PI controller should give a duty ratio between 0 and 1
Which I will convert to a PWM signal (which needs the *255)
Okey, I misread one declaration.
Add some temporary Serial.println of the key variables just before analogWrite and watch Serial monitor to see where things go wrong.
Which controller?
Uno.
Which controller? I guess a PI one.
I changed my code to the following:
#include <PID_v1.h>
double alpha;
double Input,Output,Setpoint;
PID myPID(&Input,&Output,&Setpoint,5,0.5,0,REVERSE); //Normally this should attain voltage we want in 6sec
unsigned long PIDtijd = -6000;
myPID.SetSampleTime(6000);
int beta;
Input = analogRead(SpanningTreinLezer)*20.0/1023.0;
Setpoint = 4+analogRead(WensSpanningLezer)*5/1023.0;
if (WerkelijkeTreinspanning<4) {
analogWrite(MosfetPin,255);
PIDtijd = millis();
else {
Serial.println(Output);
As you can see my PID library generates an output (which I checked with serialprint) it indeed calculates something. Which is a duty cycle 'alpha' of a pwm so 0.8 means 80% of the time I want a high pwm pulse to my mosfetpin. (it's after the line myPID.compute())
But I don't how i can change the output signal in beta, can I do something like this: beta=Output*255?
Thanks, snor
