I'm trying to rig up a PID controller for a mash tun using a DS18b20 temp sensor on pin 3 and a n SSR on pin 11. My programming skills are next to zero so I'm surprised I made it as far as I have on m,y own. I can read the temp probe but I'm having trouble handing off it's input to the PID library. I'm sure I'm missing something simple but could use some help. Here's the sketch:
#include <PID_v1.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
#define PIN_OUTPUT 11
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Define the aggressive and conservative Tuning Parameters
double aggKp=4, aggKi=0.2, aggKd=1;
double consKp=1, consKi=0.05, consKd=0.25;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// Arduino 1-Wire Address Finder
DeviceAddress HLTlow = { 0x28, 0xFF, 0xC5, 0xE9, 0x64, 0x15, 0x02, 0xF6 };
void setup(void)
// start serial port
// Start up the library
sensors.begin();
// set the resolution to 10 bit (good enough?)
sensors.setResolution(HLTlow, 10);
//initialize the variables we're linked to
Input = ONE_WIRE_BUS 3;
Setpoint = 100;
//turn the PID on
myPID.SetMode(AUTOMATIC);
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
Serial.print("Error getting temperature");
Serial.print("C: ");
Serial.print(tempC);
Serial.print(" F: ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
delay(2000);
Serial.print("Getting temperatures...\n\r");
sensors.requestTemperatures();
Serial.print("Low HLT temp: ");
printTemperature(HLTlow);
Serial.print("\n\r");
Serial.print("\n\r\n\r");
double gap = abs(Setpoint-Input); //distance away from setpoint
if (gap < 10)
{ //we're close to setpoint, use conservative tuning parameters
myPID.SetTunings(consKp, consKi, consKd);
//we're far from setpoint, use aggressive tuning parameters
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
analogWrite(PIN_OUTPUT, Output);
And here's my error message on compiling:
Arduino: 1.6.12 (Linux), Board: "Arduino/Genuino Uno"
/home/pi/Desktop/firstarduino/PID_controller/PID_controller.ino: In function 'void setup()':
PID_controller:48: error: expected ';' before numeric constant
/home/pi/Desktop/firstarduino/PID_controller/PID_controller.ino: In function 'void loop()':
PID_controller:79: error: expected ';' before numeric constant
exit status 1
option enabled in File -> Preferences.
