piezo and external interrupt
Hi there, i want to use a piezo to wakeup an arduino when someone knock a door.. The documentation says that it's only possible catching LOW states on digital pin.. What is the circuit i need to add to have 0V when it detects the knock and 5V when there is no knock? btw, sorry about my low english skills...
Thank you very much and have a nice weekend!
after reading ATmega 1280 datasheet i see that using pin change interrupts i can do what i need by software.. i share here the piece of code i wrote (part of it is the ArduinoSleepCode example), if someone need it.. i have tested it a little and it seems to work ok... but if someone can explain me what are the components i need to do what i asked before(0V when it detects the knock and 5V when there is no knock), i will be very pleased...
#include <avr/interrupt.h>
int wakePin = 53;
pinMode(wakePin, INPUT);
Serial.begin(9600); // Debugging only
Serial.println("setup");
miattachinterrupt();
void miattachinterrupt()
PCICR=0;
PCMSK0=0;
PCMSK1=0;
PCMSK2=0;
PCMSK0 |= (1 <<PCINT0);
PCICR |= (1<<PCIE0);
sei();
void midetachinterrupt()
PCICR=0;
PCMSK0=0;
PCMSK1=0;
PCMSK2=0;
cli();
ISR(PCINT0_vect) //i dont do nothing
void sleepNow()
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
sleep_mode();
sleep_disable();
midetachinterrupt();
int count = 0;
count++;
Serial.print(",Awake for ");
Serial.println(count);
delay(100);
if (count >= 50) {
Serial.println("Timer: Entering Sleep mode");
delay(100);
count = 0;
sleepNow(); // sleep function called here
