Piezo counter Input
Hello. I have a Piezo knock sensor and I want it to signal a counter on a seven segment display for each knock. I have a counter that is running on a clock but I need help adding the sensor as an input for the counter.
'''Displays the numbers 0-9 on the display, at one second intervals
Implemented using 5611AH - 8-segment display
Pin assignment for 5611AH
G F com A B
| 10 9 8 7 6 |
| 1 2 3 4 5 |
E D com C P
A=7,B=6,C=4,D=2,E=1,F=9,G=10,P=5,com=GND
LED segment assignment corresponding to pins
A
F | | B
G
E
--- . P
D
// Pin 2-8 is connected to the 7 segments of the display.
int pinA = 8;
int pinB = 9;
int pinC = 4;
int pinD = 3;
int pinE = 2;
int pinF = 7;
int pinG = 6;
int pinP = 5;
int D1 = 10;
int D2 = 11;
int D3 = 12;
int D4 = 13;
// initialize the digital pins as outputs.
pinMode(pinA, OUTPUT);
pinMode(pinB, OUTPUT);
pinMode(pinC, OUTPUT);
pinMode(pinD, OUTPUT);
pinMode(pinE, OUTPUT);
pinMode(pinF, OUTPUT);
pinMode(pinG, OUTPUT);
pinMode(pinP, OUTPUT);
pinMode(D1, OUTPUT);
pinMode(D2, OUTPUT);
pinMode(D3, OUTPUT);
pinMode(D4, OUTPUT);
void loop() {int pinA = 8;
int pinB = 9;
int pinC = 4;
int pinD = 3;
int pinE = 2;
int pinF = 7;
int pinG = 6;
int pinP = 5;
int D1 = 10;
int D2 = 11;
int D3 = 12;
int D4 = 13;
digitalWrite(pinA, HIGH);
digitalWrite(pinB, HIGH);
digitalWrite(pinC, HIGH);
digitalWrite(pinD, HIGH);
digitalWrite(pinE, HIGH);
digitalWrite(pinF, HIGH);
digitalWrite(pinG, LOW);
digitalWrite(pinP, LOW);
delay(500); // wait for a second
digitalWrite(pinP, HIGH);
digitalWrite(pinA, LOW);
digitalWrite(pinD, LOW);
digitalWrite(pinE, LOW);
digitalWrite(pinF, LOW);
digitalWrite(pinC, LOW);
digitalWrite(pinG, HIGH);
digitalWrite(pinB, LOW);
Also I tried to format the code I dont think it worked
Does your code even compile?
It looks like you have embedded setup inside loop.
Please remember to use code tags when posting code.
Hi @mickgullace
pizoelectric sensors can generate voltage spikes of up to a few tens of volts.
These spikes can damage electronic device inputs.
When using them as inputs for electronic devices, protect the input of these devices with some feature, such as zener diodes.
It works enough to display a 1-9 count. I dont know what you mean by code tags. I am very new.
The code you posted does not compile.
It has multiple setup() and multiple loop() functions.
Please post the code you claim works, in code tags.
int pinA = 8;
int pinB = 9;
int pinC = 4;
int pinD = 3;
int pinE = 2;
int pinF = 7;
int pinG = 6;
int pinP = 5;
int D1 = 10;
int D2 = 11;
int D3 = 12;
int D4 = 13;
int pinB = 9;
int pinC = 4;
int pinD = 3;
int pinE = 2;
int pinF = 7;
int pinG = 6;
int pinP = 5;
int D1 = 10;
int D2 = 11;
int D3 = 12;
int D4 = 13;
Is this better?
Code tags, good
Code that doesn't compile, bad
What do you mean that it doesnt compile? What do I need to change? It is working on my breadboard.
It's obvious that code doesn't compile.
It has more than one setup and more than one loop
And that doesn't compile either.
When you've got some code that compiles, copy it from the IDE window and post it here, intact, in code tags.
Otherwise, we're just wasting time.
So just because it works doesn't mean it "compiles"? I am trying to upload a video of it working but the video wont format.
For a couple of reasons, the code you posted last cannot compile, therefore it cannot upload, therefore it cannot run, and if it cannot run, it cannot be said to work.
This is also not an installation issue.
Your post was MOVED to its current location as it is more suitable.
