piezo-knocks problem
Hi everyone,
I am new in Arduino. I bought the starter kit and I am trying to do the projects which are in the book of starter kit.
I have problem with piezo. I cannot undesrtand what is going on!!
I am on project 12 (if know the book) . You knock the piezo 3 times and then a servo motor is moving.
Anyway, when I knock on the piezo once, then in the serial monitor I see 2 knocks!!!
#include <Servo.h>
Servo myServo;
const int piezo=A0;
const int switchPin=2;
const int yellowLed=3;
const int greenLed=4;
const int redLed=5;
int knockVal;
int switchVal;
const int quietKnock=10;
const int loudKnock =100;
boolean locked =false;
int nunberOfKnocks =0;
  myServo.attach(9);
  pinMode(yellowLed,OUTPUT);
  pinMode(redLed,OUTPUT);
  pinMode(greenLed,OUTPUT);
  pinMode(switchPin,INPUT);
   digitalWrite(greenLed, HIGH);
   myServo.write(0);
   Serial.println("the box is unlocked");
  if (locked == false)
    switchVal=digitalRead(switchPin);
    if (switchVal == HIGH)
      nunberOfKnocks=0;
      locked= true;
      digitalWrite (greenLed, LOW);
      digitalWrite(redLed,HIGH);
      myServo.write(90);
      Serial.println("the box is locked");
  if (locked ==true)
    knockVal= analogRead(piezo);
    if (nunberOfKnocks <3 && knockVal >0)
      if(checkForKnock(knockVal)==true)
        nunberOfKnocks++;
      Serial.print(3-nunberOfKnocks);
      Serial.println("   more knocks to go");
    if (nunberOfKnocks >=3)
      locked=false;
      myServo.write(0);
      delay(20);
      digitalWrite(redLed, LOW);
boolean checkForKnock(int value)
  Serial.print("In function: value=");
    Serial.println(value);
  if (value> quietKnock && value < loudKnock)
    digitalWrite(yellowLed, HIGH);
    delay (50);
    digitalWrite(yellowLed,LOW);
    Serial.print("Valid knock of value");
    return true;
    Serial.print("Bad kncock value");
    Serial.println (value);
    return false;
Can anyone explain me why this happening??? ?
Yes, it is a "debounce" problem - the piezo is generating an output for longer than the time the program waits after detecting a "knock".
The more important question is - is it flagging "valid" knocks and will it operate the servo if you knock a number of times?
You could increase the delay in
    delay (50);
to 100.
