Hey! I’ve made this project. The idea is, when the temperature reader reaches +24 degrees, it will play a sound from a piezo knock sensor, and do a flashing light with the yellow bulb.
At the same time, the knock sensor will take inputs as i tap on it. If it reaches above the set threshold, it will change the red LED to the green LED.
It works separately, but not together.
Any tips?
//variabler til lås
const int redPin = 13;
const int greenPin = 12;
const int knockSensor = A1;
const int threshold = 100;
int sensorReading = 0;
int lockLedState = HIGH;
//variabler til temperatur
const int temperaturePin = A4;
const int yellowPin = 11;
int temperaturLedState = HIGH;
unsigned long previousMillis = 0;
int tempRead = 0;
//variabler til lyd
int soundLedState = LOW;
//knockSensor A1, noteA, noteB;
char ON_OFF;
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(yellowPin, OUTPUT);
sensorReading = analogRead(knockSensor);
lockSensor();
getTemperature(temperaturePin);
float getTemperature(int temperaturePin) {
float voltRead = analogRead(temperaturePin);
float volt = voltRead * (5.0 / 1023);
float voltInCelc = (volt - 0.5) * 100;
// Serial.println(voltInCelc);
if (voltInCelc >= 25 || voltInCelc <= 1) { //Til tests er det 24 - normalt køleskab er måske maks 7 *c.
ON_OFF = 'A';
temperaturAlarm(50);
piezoSound();
ON_OFF = 'B';
Serial.print("Reset");
return voltInCelc;
void temperaturAlarm(int interval) {
if (ON_OFF == 'A') {
if (currentMillis - previousMillis >= interval) {
if (temperaturLedState == LOW) {
soundLedState = HIGH;
temperaturLedState = LOW;
digitalWrite(yellowPin, temperaturLedState);
void piezoSound() {
const int noteA = 440;
const int noteB = 750;
if (soundLedState == LOW) {
tone(knockSensor, noteA);
} else if (soundLedState == HIGH) {
tone(knockSensor, noteB);
void lockSensor() {
Serial.print(sensorReading);
if (ON_OFF == 'B') {
if (sensorReading >= threshold) {
lockLedState = !lockLedState;
digitalWrite(greenPin, lockLedState);
digitalWrite(redPin, !lockLedState);
delay(200);
//LAV EN LAMPE DER KAN JUSTERE LYSSTYRKE FRA DREJEKNAP
//ENTEN BOOLEAN ELLER SEND TIL PROCESSING ELLER GOTO
//FRITZING
//MANGLER: LockSensor virker ikke ordenligt.
Thanks!
Regards, Simon.
