piezo on and off
hi all
I found this example
http://arduino.cc/en/Tutorial/Knock
and saw this code
const int ledPin = 13;      // led connected to digital pin 13
const int knockSensor = A0; // the piezo is connected to analog pin 0
const int threshold = 100;  // threshold value to decide when the detected sound is a knock or not
// these variables will change:
int sensorReading = 0;      // variable to store the value read from the sensor pin
int ledState = LOW;         // variable used to store the last LED status, to toggle the light
 pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT
 Serial.begin(9600);       // use the serial port
  // read the sensor and store it in the variable sensorReading:
  sensorReading = analogRead(knockSensor);
  // if the sensor reading is greater than the threshold:
  if (sensorReading >= threshold) {
    // toggle the status of the ledPin:
    ledState = !ledState;
    // update the LED pin itself:
    digitalWrite(ledPin, ledState);
    // send the string "Knock!" back to the computer, followed by newline
    Serial.println("Knock!");
  delay(100);  // delay to avoid overloading the serial port buffer
so i tried to change it a bit to make it tap once on and tap once off
but it works sometimes(tap once the led on and tap once the led off) but it doesn't work sometimes (tap once the led on but i had to tap a few times to turn it off)
const int ledPin = 9;      // led connected to digital pin 13
const int threshold = 3;  // threshold value to decide when the detected sound is a knock or not
int sensorReading = 0,sensorReading1 = 0;      // variable to store the value read from the sensor pin
    digitalWrite(ledPin, HIGH);
 if (sensorReading1 >= threshold) {
    digitalWrite(ledPin,LOW);}
note: if i set the threshold above 3 it doesn't work
the led goes on then off or I had to tap very hard to turn on the led)
Please show me how to make this simple code work
Thanks
But you aren't reading anything into the variable "sensorReading1".....
sensorReading1 = analogRead(knockSensor);
I copied it wrongly
I do have the second line in the code
thanks for replying
