piezo sensor
Is they a way to use a pot switch to control the sensitivity of a piezo sensor?
Thank you
Have you tried it parallel with your piezo? When you reduce the resistance in parallel, the signal from piezo is cutted. What potentiometer you have, in ohms?
Try connecting other side of the pot to analog in, an the other side to GND, piezo analog in and middle of the pot.
I don't know the levels of the piezo element, so I can only recommend quite big one, 100k-1M.
Cheers, Kari
Thank you for your response. I am using a 10K Pot.
Yes...?
How is it connected? Does it work as expected?
Kari
I just tried it in para. It is not working. However the problem maybe with the code as I am getting a sync error what ever that is.
