Hi All,
I am working on a project where I need 3 x Piezo switches connected (one will be Ent, + and -).
As most would know, pushing a piezo button creates a small voltage (2-4v for a split second when bushed and released).
Firstly, I would like to know if I should use analog or digital inputs. I think Analog, as I can then "tune" how hard the switch needs to be pressed for it to trigger (Like the Knock Sensor project).
But............
How do I read these analog ports while the code is running? If the switch is pushed while in the loop part of the code, How do I record that it was pushed and then inspect it during the code (as it is an analog connection)? If it was digital, I could use StateChange I think - http://arduino.cc/en/Tutorial/ButtonStateChange.
Thanks in advance...
