Hi, I am building a drum midi module (microdrum SW) with a arduino Mega and having some problems with the piezoelectric not working. When touched with my fingers there is a light in midi software (AD2) that reacts. But if i hi them they do nothing.
I tried grounding all the unused analog pins. The piezo signal goes thru a 1M resistor and a 5.1 Zener Diode conected in paralel with ground. Any ideas?
I finally figured it out. Everything was right. The probleme were the piezos. Which apparently work only as skpeakers. I connected a roland pad and tested every input and works prefectly.
