Hello there, I'm a civil engineering major and I'm a gradate doing a master degree in piezoelectric sensors to be used in the structural health monitoring. i have installed the board and the connections and jumpers but the problem is when trying to view the output in the tools> serial monitor the board keeps spamming knock which what it is supposed to do if it detect a knock but there isn't any knock. even if i disconnect the sensor entirely it still keeps sending knock signs. that's one problem the other one is there a way to show this data on a graph instead of just the word knock. I'm very new to this as you can see and really need the help.
thanks everyone
Links to the datasheets as well as autoformatted code pasted in code tags is requested.
Schematics are often valuable.
Far too many pronouns ![]()
- the board
- the connections
- the output
- the sensor
just the word knock?
Please re-read your post. Consider those of us reading you post have no prior knowledge of what you are doing. Then consider what we could possibly provide with your posted information.
I mean no offence but you level of detail for a degreed engineer is more like I would expect from a freshman in high school.
Then you should be able to make a comprehensive post describing your problem
