Piloter le GPIO de l’ESP8266 (Serveur Web) depuis Domoticz en TCP/IP sans fil
Bonjour j’ai utilisé ce script https://projetsdiy.fr/piloter-gpio-esp8266-web-serveur-domoticz-partie2/
j’ai rencontré un problème de compilation,
voici ce qu’il marque, je ne comprends pas que ça ne marche pas, j’ai pourtant prit ce code qui marche normalement.
Bonjour,
quand je compile ça me dit ça, je ne comprend pas
sketch_dec01a:17:29: error: ‘D1’ was not declared in this scope
const uint8_t GPIOPIN[5] = {D1,D5,D6,D7,D8}; // Led
sketch_dec01a:17:32: error: ‘D5’ was not declared in this scope
sketch_dec01a:17:35: error: ‘D6’ was not declared in this scope
sketch_dec01a:17:38: error: ‘D7’ was not declared in this scope
sketch_dec01a:17:41: error: ‘D8’ was not declared in this scope
sketch_dec01a:9:19: error: ‘D4’ was not declared in this scope
#define DHTPIN D4 // Broche du DHT / DHT Pin
C:\Users\marsf\Documents\Arduino\sketch_dec01a\sketch_dec01a.ino:19:9: note: in expansion of macro ‘DHTPIN’
DHT dht(DHTPIN, DHTTYPE);
C:\Users\marsf\Documents\Arduino\sketch_dec01a\sketch_dec01a.ino: In function ‘void updateGpio()’:
sketch_dec01a:36:13: error: ‘D1’ was not declared in this scope
int pin = D1;
sketch_dec01a:40:11: error: ‘D7’ was not declared in this scope
pin = D7;
sketch_dec01a:42:11: error: ‘D8’ was not declared in this scope
pin = D8;
C:\Users\marsf\Documents\Arduino\sketch_dec01a\sketch_dec01a.ino: In function ‘void setup()’:
sketch_dec01a:61:14: error: ‘D2’ was not declared in this scope
Wire.begin(D2,D3);
sketch_dec01a:61:17: error: ‘D3’ was not declared in this scope
Wire.begin(D2,D3);
exit status 1
Bonjour,
Tu es sur que tu as déclaré la bonne carte (dans le menu outils) ?
j’ai essayé avec une autre carte et ça semble marcher, merci
