Pimoroni breakout board output problem
I bought Pimoroni breakout board based on ADS1015 Texas Instruments 12 bit ADC, it has capability of measuring 24V voltage. Problem is that I want to use Arduino board for the measurement and Pimoroni only shares Python code for their product. I thought that if it is based on ADS1015, I can use any Arduino library for ADS1015 and it should be working… and it is, sort of. I used a couple of libraries, and there is practically the same case. As I understand for voltage 0 V the output should be around 0 bytes. For different libraries the output is different and certainly is not 0. I attach Arduino program for Sparkfun library (I tried also Adafruit, and Rob Tilaart library).
obraz
The output for 0V, both wire connected to GND on Arduino: 1183.
The output for 3.3V, one wire connected to 3.3V on Arduino, second to GND: 1340.
The output for 5V, one wire connected to 5V on Arduino, second to GND: 1420.
Therefore for 0V to 3.3V -> 3.3V/(1340-1183)=3.3V/157=0.021 V/bit
For 3.3 to 5V ->(5-3.3)/(1420-1340)=1.7 V/80=0.0212 V/bit
So the formula: (channel_A3-1183)*0.021 works. Why is it not symmetrical, I mean it should be 0 for 0V, 2048 for 24V and -2048 for -24V, why is not the case, is it the issue with reading the I2C signal?
uint16_t channel_A3 is an unsigned integer and cannot represent negative numbers.
I'd have expected a 12bit ADC to output a range 0 to 4095. If it is capable of handling negative voltages, then 0 volts would be mid scale at 2047.
Post code as text, not pictures.
That's fine, if reading are single-ended.
Negative numbers are only expected with differential readings.
I would still use an int though.
The code comes from Github.
It has been changed to read from channel 0,
but printouts have not been changed to reflect that.
Leo..
Could be this board, which does not have A3 (only three channels instead of four).
Hello All,
thank You for your answers, first of all single-ended measurement just seems to have not symmetrical output, therefore I have changed code to differential between A0 and A1 channels:
#include <SparkFun_ADS1015_Arduino_Library.h> //Click here to get the library: http://librarymanager/All#SparkFun_ADS1015
#include <Wire.h>
ADS1015 adcSensor;
Wire.begin();
  Serial.begin(19200);
  if (adcSensor.begin() == true)
    Serial.println("Device found. I2C connections are good.");
    Serial.println("Device not found. Check wiring.");
    while (1); // stall out forever
  adcSensor.setGain(ADS1015_CONFIG_PGA_4);
int16_t channel_A0 =adcSensor.getDifferential();
Serial.print("A0_raw: ");
Serial.println(channel_A0);
Serial.print("A0:");
Serial.println(channel_A0*0.02125);
delay(500); // avoid bogging up serial monitor
Now, it is symmetrical. Different output from different ADS1015 libraries is caused by different default gains.
ADS1015_CONFIG_PGA_TWOTHIRDS +/- 6.144v
ADS1015_CONFIG_PGA_1 +/- 4.096v (used in this example)
ADS1015_CONFIG_PGA_2 +/- 2.048v
ADS1015_CONFIG_PGA_4 +/- 1.024v
ADS1015_CONFIG_PGA_8 +/- 0.512v
ADS1015_CONFIG_PGA_16 +/- 0.256v
I have chosen +/- 1.024v which gives the best resolution around 0.011V/bit, but for 24 V it goes slightly above the maximum value, the reason is before feeding to ADS1015, voltage is divided from 24V to 1.14V so slightly higher than 1.024 V.
obraz
I think the case is solved.
