pin 0 serial port
I am trying to read and display RS232 readable ascii data. I am converting the RS232 to TTL through a MAX 232 to the serial port 0 on the Arduino and display it on my LCD. I am just sending characters “RY” for testing right now at 2.4k with coding of 8N1 data to port 0 RX. I am using a simple code below. I see data come in but its all garble Is there more I need to set up this port 0?
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
lcd.init(); // initialize the lcd
lcd.backlight();
Serial.begin(2400);
// when characters arrive over the serial port…
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
test.txt (661 Bytes)
PLease use code tags when posting code (it is the # button)
#include <Wire.h>
  lcd.backlight();
  Serial.begin(2400);
  lcd.print("start");    // <<<<<<<<<<<<<<< DOES THIS WORK?
  // when characters arrive over the serial port...
    delay(100);
    // clear the screen
    lcd.clear();
      lcd.print(Serial.read());  // <<<<<<<<<<<<<<<<<<<<<<<<< CHANGED TO PRINT
does this help?
