pin 12 problem with 74HC595
Hi All,
Using ShiftRegister74HC595.h for save ports in Arduino Uno.
With this library you can set each pin of HC595 individually (Q0 to Q7 or pin 15(0) and pin 1 to 7).
For now I'm using leds simulating the digital potentiometers UP/DOWN and chip select pins.
The problem is that the pin 12 is the output for latch of HC595, then when I push the button for to set the pins and light up the corresponding leds nothing happens or the wrong leds light up, if I place my hands over the wire of pin 12 the leds light up ok.
Seems that have a high frequency circulating by the wire
Some body have a clue?
ps: If I build this on the Mega 2560 the problem don't arise.
Do you have MRClear connected or pulled high, and OE/ connected to Gnd, or driven low?
Thanks for replay,
Yes pin 10 is connected direct to 5V and pin 13 direct to ground.
But if I use the Mega 2560 this not happens.
(deleted)
Sadly is not the case, I make a test with a multimeter in the continuity scale from 18 pin of CI and show 0 ohm to respective pin in the breadboard. Make this after a reinforcing of pin out in the Arduino's board.
I am new to Arduino and was thinking about some fuse bit or so but encountered nothing about.
I see that the pin 12 of Arduino is MISO/PCINT4 too but don't know if this can affect the working of this bit in the PORTB.
I have configured the pinMode(12, OUTPUT); too but nothing is changed.
I go to replace the ATMega 328pu and see if solve the problem.
Now I recorded the boot loader in a new ATMega 328pu and replaced the onboard ATMega 328.
Works in exact same with pin 12 with the problem...
Then, I replace the 74HC595 and the problem persists.
So the chalenge continues...
Well, how the pin 12 is MISO I have configured it how a digital in and solve the problem but the mystery continues...
