Pin 5/9 PWM Out difference
My system: Arduino Uno and Multi-function Shield.
I programmed simple Code to change PWM out with onboard Potentiometer.
The problem: output 5 behaves as expected if I switch Code to Out 9
PWM signal does not correspond to Potentiometer changer, but rather stays
the same till Pot reaches the Highest Value of 255 Than PWM is Full ON
Description: Varies the brightness of the leds based on
             the value read in from the potentiometer.
#include <TimerOne.h>
#include <Wire.h>
#include <MultiFuncShield.h>
#define DEBUG 1 // 0 - Turn off serial monitor - 1 turn on.
int pinLedD1 = 13;  // Define the D1 pin as led (on most arduino boards this is NOT a PWM pin.
int pinLedD2 = 12;  // Define the D2 pin as led (on most arduino boards this is NOT a PWM pin.
int pinLedD3 = 11;  // Define the D3 pin as led.
int pinLedD4 = 10;  // Define the D4 pin as led.
int motorPWM = 5; // Define Motor PWM pin
int pinPotentiometer = A0;  // Define Analog pin A0 as Potentiometer.
unsigned int uiPotentiometerValue = 0;
   Timer1.initialize();
  MFS.initialize(&Timer1);    // initialize multi-function shield library
  #if DEBUG
    Serial.begin(9600); // Set baud rate to 9600.
  #endif
  // Define the led pins to be output.
  pinMode(pinLedD1, OUTPUT);
  pinMode(pinLedD2, OUTPUT);
  pinMode(pinLedD3, OUTPUT);
  pinMode(pinLedD4, OUTPUT);
  pinMode(motorPWM, OUTPUT);
  unsigned int uiPWM; // Pulse width modulation value.
  uiPotentiometerValue = analogRead(pinPotentiometer);
  // Sensor resolution is 0 - 1023.
  // PWM has range of 0 - 255 therefore divide by 4.
  uiPWM = uiPotentiometerValue / 4;
  int LEDPWM = uiPWM;
  MFS.write(LEDPWM);
  analogWrite(motorPWM, LEDPWM);  // PWM Motor Drive
  #if DEBUG
    // Output text to serial port.
    Serial.print("Potentiometer = ");
    Serial.print(uiPotentiometerValue);
    Serial.print("  PWN Value = ");
    Serial.println(uiPWM);
  #endif
  // Set the level of brightness.
  analogWrite(pinLedD1, (255 - uiPWM)); // Not a PWM pin - will be on or off.
  analogWrite(pinLedD2, uiPWM);         // Not a PWM pin - will be on or off.
  analogWrite(pinLedD3, (255 - uiPWM)); // Reverse to show contrast.
  analogWrite(pinLedD4, uiPWM);
  delay(100); // Delay for 10th of a second.
Pin 9 uses Timer1 to create PWM. Will that still work with this library included? Or is the library taking over control of the timer?
Delta_G:
You are right, Library probably takes over.
But I’m still confused, why I do get confusing PWM signal from Out 9
that responds to Full Pot Value only.
Why? Reread the first sentence of your last reply for the answer. You said it yourself.
thank you
