Pin 9 and 10 on ATMega328 question
Normally these 2 pins are used for external oscillator but the chip can be programmed to use internal clock instead for stand alone operation (not on Arduino board but custom PCB or breadboad). I looked at the pinouts and it's listed as PB6 and PB7 which means theoretically I can use that 2 pin via direct port manipulation as group port B. But there seems to be no way to control that 2 pins by itself like digitalWrite.
Is there a way to control pin 9 and 10 within IDE as individual pins?
Configure PB6 as an output...
DDRB |= (1 << DDRB6);
Configure PB6 as an input...
DDRB &= ~(1 << DDRB6);
Read PB6...
(PINB & (1 << PINB6));
Set PB6 HIGH...
PORTB |= (1 << PORTB6);
Set PB6 LOW...
PORTB &= ~(1 << PORTB6);
Toggle PB6...
PINB = (1<< PINB6);
Warning: may contain syntax or logical errors
MiniCore supports PB6 and PB7 as pins 20 and 21.
Cool it's easier than I thought. Thanks for the info
