Pin alias so I don't need to change code or rewire
Hey,
I have a xmas light controller I made. It originally flipped a set of 8 relays on and off to make light patterns. Like so:
  for(int i = 1; i <= 8; i++) {
    pinMode(i, OUTPUT);
 // wave up
  for(int x = 1; x<=4; x++)  {
        digitalWrite(i, HIGH);
      for(int i = 0; i <= 8; i++) {
        digitalWrite(i, LOW);
      delay(2000);
etc, more patterns
Problem is relays 1 and 7 have burned out. I could go in and rewire the thing. I could just run it as is and not use 1 and 7.
What I want to know is if there is some sort of alias I can assign in my set up to just use pins 2, 3, 4, 5, 6, and 8 without having to drastically rewrite everything. All the patterns would then run as x<= 3 and i < 6 is my idea.
In the setup can I do something like
pin1= 2
pinMode(pin1, OUTPUT)
and then in the loops do something like
digitalWrite("pin" + i, OUTPUT)
Obviously, I don't have the correct syntax.
Many thanks in advance.
Not like that. Names do not exist in the compiled code, so you can't set the mode based on the name.
Using an array of pin numbers, and iterating in the loops over the pins in the array, based on the sizeof the array means that when you replace the burned out relay (how DID that happen?), you just add another pin number to the array, and no other changes are needed.
Ah ha! An array.
So my setup then looks like:
int myPins[] = {2, 3, 4, 5, 6, 8};
for(int i = 1; i <= 6; i++) {
    pinMode(myPins[i], OUTPUT);
And my loops do
digitalWrite(myPins[i], HIGH);
etc
That right?
Oh, and inexpensive foreign product running outside for a couple of weeks is how a relay fails.
No, because the compiler can count better than you.
What happens if you add a pin? You have to change the 6 everywhere. Let the compiler do that.
Oh, and array indices start at 0.
byte myPins[] = {2, 3, 4, 5, 6, 8};
byte pinCount = sizeof(myPins) / sizeof(myPins[0]);
for(int i = 0; i < pinCount; i++)
Oooooo. So then I could also do
for(int i = 0; i <= pinCount; i++) {
etc
if I am following you correctly.
Hmm. I'm got
pinCount was not declared in this scope.
Put the two byte declarations outside of setup to make them global and it compiled.
I think I have functional code.
Thank you very much.
