Pin assignment encoder
Hi..
http://www.ebay.com/itm/111415126325?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I bought this motor for a project, but I am not able to see which wires are 5V, GND, sensor A and Sensor B for the encoder. Is there anybody here that know this motor?
This is how it should be : www.ebay.com/itm/151005216153
The flat ribbon cable is the optical encoder.
It seems as if your motor does not have the encoder on the motor. There should be soldered something to the 8 pins in the middle. Has that been removed ?
An optical encoder might be IR diodes with a disc with teeth, like it was used in an old mouse, encapsulated against dust.
If you can read Chinese ... I see the picture of the encoder and pinout on the bottom right.
rmetzner49, I copied that link, changed "CN" into "EN", and ... https://fmcc.faulhaber.com/resources/img/EN_TECHNICAL_INFORMATION.PDF
Problem solved then. I guess I was too tired to think of that. Thanks.
Wow, what a useful little book full of all sorts of motion control stuff!
