pin assignment
Hello,
I am new to Arduino, and have a basic question based on the very first example sketch. I understand the basic sketch functions in this example (I have no programming experience beyond DOS batch files), but no where in the setup nor in the loop did I see the actual I/O pin of the Arduino assigned. So are all the I/O pins doing the same thing in this example? I always have had a problem with details, I hope this isn't a silly question. Thanx!
How can we know which example sketch that you are referring to? And what do you mean by pin assignment?
Either post a link to the sketch or post the code here. Read the "how to use the forum-please read" stickies to see how to format and post code. See #7 and 10.
Please take a read through the sticky "Read this post before posting a programming question", then post the program you are using. There are a lot of example sketches out there (probably more example sketches than there are Arduino boards LOL).
And a LOT of those examples are not the good kind.
Edit. Which Arduino board are you using?
