typedef struct _PinDescription
EPortType ulPort ;
uint32_t ulPin ;
EPioType ulPinType ;
uint32_t ulPinAttribute ;
EAnalogChannel ulADCChannelNumber ; /* ADC Channel number in the SAM device */
EPWMChannel ulPWMChannel ;
ETCChannel ulTCChannel ;
EExt_Interrupts ulExtInt ;
} PinDescription ;
Here is an example of a description from varient.cpp { PORTA, 4, PIO_ANALOG, (PIN_ATTR_PWM|PIN_ATTR_TIMER), ADC_Channel4, PWM0_CH0, TCC0_CH0, EXTERNAL_INT_4 }, // ADC/AIN[4]
Everything after PORTA, 4 is a mystery to me. Where can I find out more information on how to set these variables and what effect they have?
IMHO, _PinDescription is moderately broken; it doesn't do the things I want it to, and it does the other things poorly and inefficiently.
However:
PORTA: pin is on PortA
4: pin is bit 4. (PA4)
EPioType: PIO_ANALOG: The Arduino primary function is an analog pin. (This field is the biggest problem. It doesn't allow for a pin having more than one possible function.)
ulPinAttribute: PIN_ATTR_PWM|PIN_ATTR_TIMER: The pin can also do PWM, using a TIMER pinmux (as opposed to a TIMER_ALT pinmux setting.)
ADC_Channel_4: which ADC channel to use, when used as analog
PWM0_CH0: which PWM channel to use.
TCC0_CH0: which timer that PWM channel is on.
EXTERNAL_INT_4: for attachInterrupt(), which external interrupt does this pin tie to.
Most of this can be gleaned from the WVariant.h file, and searching the source for use of the individual structure members.
