pin change interrupt
Hello,
At analog pin 1 I've attached a voltage divider to read some buttons
How can i read values above 500 using pin change interrupt?
Here is my code
  PORTC |= B00000010;//pull up resistor on A1
  PCICR |= (1 << PCIE1);//enable interrupt on port c
  PCMSK1 |= (1 << PCINT9);//monitor A1
  MCUCR = (1<<ISC00) | (1<<ISC01);//01 triggers at any change
  interrupts();
  InitFastAnalogRead();
//Serial.println(ReadSensor(1));
//delay(250);
unsigned int ReadSensor(byte Pin)
  unsigned int Vals = 0;
  analogRead(Pin);
  for(byte i = 0; i < 2; i++)
    Vals += analogRead(Pin);
  //Serial.print(Pin,DEC);Serial.print("=>");Serial.print(Values/2,DEC);Serial.println();
  return (Vals/2);
void InitFastAnalogRead()
  //set prescale to 16
  ADCSRA |= (1<<ADPS2);
  ADCSRA &= ~(1<<ADPS1);
  ADCSRA &= ~(1<<ADPS0);
ISR(PCINT1_vect)
I used this document to create the code
http://www.me.ucsb.edu/~me170c/Code/How_to_Enable_Interrupts_on_ANY_pin.pdf
ISR(PCINT1_vect)
Serial.print() in an ISR is really not a good idea, especially at 9600 baud.
you can't.
but you can't because interrupt on change (like all interrupt) works on digital value, not analogic. But here a trick:
if the input voltage is < 512, the for arduino this is a digital 0, if voltage >= 512 then you have a 1.
So if you want a read only when pin is HIGH (>512) then you need another trick:
the interrupt are
LOW to trigger the interrupt whenever the pin is low,
CHANGE to trigger the interrupt whenever the pin changes value
RISING to trigger when the pin goes from low to high,
FALLING for when the pin goes from high to low.
if there was an interrupt like HIGH to trigger the interrupt whenever the pin is high was ok, but there isn't
so you can do something like this (in pseudocode):
ISR(PCINT1_vect)
iHaveToRead=pinstatus;//boolean 1 or 0
loop(){
if (iHaveToRead){
in the interrupt i will call GetKey function, serial.print was only for testing
the function will look like this
byte GetKey()
  unsigned int KeyVal = ReadSensor(1);
  if(KeyVal > 865) {return Key_0;}
  byte btn = Key_0;
  delay(10);
  if(KeyVal == ReadSensor(1))
    if (KeyVal <= 865 && KeyVal > 855)
      btn = Key_M;
    else if (KeyVal <= 705 && KeyVal > 695)
      btn = Key_S;
    else if (KeyVal <= 544 && KeyVal > 534)
      btn = Key_U;
    else if (KeyVal <= 378 && KeyVal > 368)
      btn = Key_D;
    else if (KeyVal <= 206 && KeyVal > 196)
      btn = Key_L;
    else if (KeyVal <= 19)
      btn = Key_R;
  if(btn)
    while(ReadSensor(1) <= 865) {delay(5);}
    if(ROM_VAL[ROM_BackLight].Value == 2) {PORTD  |=  (1<<5); Bk_Light = millis() + 6000;}//BackLight On
  return btn;
Right now this function is called by timer2 interrupt. I've tried @ 4ms but the mcu spend too much time reading the buttons, now i read @ 30ms but i think is slow.
What is the best interval to read the buttons without too much load on the mcu?
also never put delay(10); in interrupt. interrupt has to be executed faster has you can, the best way is set some flag and let the loop do the logic, so you don't have to worry about Serial or delay.
I assure you that way i use 4 change interrupt + 3 analogic read + 1 i2c sensor and my loop is about 4ms
Normally this (the GetKey function) is way too long to be called from an ISR, especially with that delay(10) there.
What does ReadSensor() read from? If it's an analogue input there's a 1 in 1024 chance it will be == KeyVal, meaning that the following code in the if block will probably never be executed.
I would have the ISR and code more like
volatile int sensor_val;
ISR (TMR1_OVL_vect) { // I forget the actual timer vector name but you cannot use a PCINT_vect
   sensor_val = ReadSensor(1);
loop () {
  if (sensor_val > 856) ... etc etc
Rob
Thank you all for the help provided.
I manage to get the right delay for buttons debouce and i call getkey function from a loop, so i don'd need the interrupt anymore
