Pin damage in basic Switch example?
I've seen this in many tutorials introducing switches,
However, when pushing the button, the Arduino's pin voltage is about 5V! That's not good!
Am I missing something?
That's not good!
Why not?
redraw:
Yes, this page says:
Each of the 14 digital pins on the Uno can be used as an input or output, using pinMode(), digitalWrite(), and digitalRead() functions. They operate at 5 volts.
Yes that would not be good if you ever made the pin an output, then made it LOW, then pushed the switch. :sob:
If you can't trust yourself with pinMode then this could be safer.
This explains the two ways to wire up a push button.
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
redraw:
I've seen this in many tutorials introducing switches, ... Am I missing something?
Yes. You are missing out on a great deal of knowledge. Those tutorials are - sadly - not written by engineers with any particular competence! :astonished:
that doesn't mean they are wrong, and actually, in this case, they are OK :wink:
alnath:
They are not OK. That one works but that does not make it OK. There is a lot more to good engineering practice than simple functionality. That applies not only to hardware but to software perhaps even more so.
Regardless of the physical pin / switch / resistor configuration, surely the point we should be making to the OP and which I tried to do in reply #2, is that it's ok to take a pin to 5V (on a 5V Arduino anyway). But as LarryD pointed out, the pin needs to be set as in input with pinMode.
The OP's concern was, after all, about the wisdom of connecting a pin to 5V.
My head was thinking in OUTPUT mode. You're right. In INPUT mode it's fine. It's good to make it clear.
In fact, if I'm not wrong, there's a huge resistance when it's on INPUT mode, as the official web says,
"Pins configured this way are said to be in a high-impedance state. Input pins make extremely small demands on the circuit that they are sampling, equivalent to a series resistor of 100 megohm in front of the pin."
So there's no need to add 100-ohm before the pin. Why some people prefer to do that?
Read those replies again they told you.
In case you make a mistake and program the pin to be an output, and program that output to be a zero and press the button.
Well, I read that! but I thought there was ANOTHER reason.
Thanks for your help.
