Many libraries (such as Eigen) and sketches may use variables such as A0-A5 and D0-D15 as variables versus pins definitions in pins_arduino.h:
#undef A0
#undef A1
#undef A2
#undef A3
#undef A4
#undef A5
static const uint8_t A0 = PIN_A0;
static const uint8_t A1 = PIN_A1;
static const uint8_t A2 = PIN_A2;
static const uint8_t A3 = PIN_A3;
static const uint8_t A4 = PIN_A4;
static const uint8_t A5 = PIN_A5;
// Digital pins
#undef D0
#undef D1
#undef D2
#undef D3
#undef D4
#undef D5
#undef D6
#undef D7
#undef D8
#undef D9
#undef D10
#undef D11
#undef D12
#undef D13
#undef D14
#undef D15
#define D0 (0u)
#define D1 (1u)
#define D2 (2u)
#define D3 (3u)
#define D4 (4u)
#define D5 (5u)
#define D6 (6u)
#define D7 (7u)
#define D8 (8u)
#define D9 (9u)
#define D10 (10u)
#define D11 (11u)
#define D12 (12u)
#define D13 (13u)
#define D14 (14u)
#define D15 (15u)
So if you run a simple sketch:
while(!Serial && millis() < 5000) {}
int D0 = 1;
Serial.println(D0);
//digitalWrite(D0, HIGH);
void loop() {}
it will throw an error:
C:\Users\Merli\AppData\Local\Temp\.arduinoIDE-unsaved2023612-22120-liswj5.0ensn\sketch_jul12a\sketch_jul12a.ino: In function 'void setup()':
C:\Users\Merli\AppData\Local\Temp\.arduinoIDE-unsaved2023612-22120-liswj5.0ensn\sketch_jul12a\sketch_jul12a.ino:4:12: error: lvalue required as left operand of assignment
int D0 = 1;
exit status 1
Compilation error: lvalue required as left operand of assignment
A more complex example would be using Eigen:
In file included from
C:\Users\Merli\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.0.2\cores\arduino/Arduino.h:125:0,
from C:\Users\Merli\AppData\Local\Temp\arduino\sketches\019E3DD99F1ECF6C34FCED459E6CC679\sketch\eigen_example.ino.cpp:1:
d:\Users\Merli\Documents\Arduino\libraries\eigen-main\src/Eigen/src/Core/products/GeneralBlockPanelKernel.h: In member function 'void Eigen::internal::lhs_process_one_packet<nr, LhsProgress, RhsProgress, LhsScalar, RhsScalar, ResScalar, AccPacket, LhsPacket, RhsPacket, ResPacket, GEBPTraits, LinearMapper, DataMapper>::operator()(const DataMapper&, const LhsScalar*, const RhsScalar*, ResScalar, Eigen::Index, Eigen::Index, Eigen::Index, Eigen::Index, Eigen::Index, Eigen::Index, int, Eigen::Index, Eigen::Index, Eigen::Index, Eigen::Index, Eigen::Index)':
C:\Users\Merli\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.0.2\variants\MINIMA/pins_arduino.h:56:16: error: lvalue required as unary '&' operand
#define D0 (0u)
d:\Users\Merli\Documents\Arduino\libraries\eigen-main\src/Eigen/src/Core/products/GeneralBlockPanelKernel.h:1270:73: note: in expansion of macro 'D0'
peeled_kc_onestep(1, blA, blB, traits, &A1, &rhs_panel, &T0, &D0, &D1, &D2, &D3);
only one sample error. To correct this pins_arduino.h can be changed to (same way you did it for the analog pins):
// Digital pins
#define PIN_D0 (0u)
#define PIN_D1 (1u)
#define PIN_D2 (2u)
#define PIN_D3 (3u)
#define PIN_D4 (4u)
#define PIN_D5 (5u)
#define PIN_D6 (6u)
#define PIN_D7 (7u)
#define PIN_D8 (8u)
#define PIN_D9 (9u)
#define PIN_D10 (10u)
#define PIN_D11 (11u)
#define PIN_D12 (12u)
#define PIN_D13 (13u)
#define PIN_D14 (14u)
#define PIN_D15 (15u)
#undef D0
#undef D1
#undef D2
#undef D3
#undef D4
#undef D5
#undef D6
#undef D7
#undef D8
#undef D9
#undef D10
#undef D11
#undef D12
#undef D13
#undef D14
#undef D15
static const uint8_t D0 = PIN_D0;
static const uint8_t D1 = PIN_D1;
static const uint8_t D2 = PIN_D2;
static const uint8_t D3 = PIN_D3;
static const uint8_t D4 = PIN_D4;
static const uint8_t D5 = PIN_D5;
static const uint8_t D6 = PIN_D6;
static const uint8_t D7 = PIN_D7;
static const uint8_t D8 = PIN_D8;
static const uint8_t D9 = PIN_D9;
static const uint8_t D10 = PIN_D10;
static const uint8_t D11 = PIN_D11;
static const uint8_t D12 = PIN_D12;
static const uint8_t D13 = PIN_D13;
static const uint8_t D14 = PIN_D14;
static const uint8_t D15 = PIN_D15;
this gets rid of the error messages in the same sketch and when using the Eigen Library for instance.
Note: would just do the PR but leery about signing a CLA for things like this especially since the Core is under MIT license.
