Pin interrupt config
Hi, I'm rewriting the GRBL library for RAMPS and changing the PINS, however I'm lost on the interrupts ... Is there any guide/info on how to double check I got it OK? I did highlight the questionable settings in red.
Original code
define LIMIT_DDR DDRB
define LIMIT_PORT PORTB
define LIMIT_PIN PINB
define X_LIMIT_BIT 4 // MEGA2560 Digital Pin 10
define Y_LIMIT_BIT 5 // MEGA2560 Digital Pin 11
define Z_LIMIT_BIT 6 // MEGA2560 Digital Pin 12
define LIMIT_INT PCIE0 // Pin change interrupt enable pin
define LIMIT_INT_vect PCINT0_vect
define LIMIT_PCMSK PCMSK0 // Pin change interrupt register
New code - changed to PORT E
define LIMIT_DDR DDRE
define LIMIT_PORT PORTE
define LIMIT_PIN PINE
define X_LIMIT_BIT 5 // MEGA2560 Digital Pin 3
define Y_LIMIT_BIT 4 // MEGA2560 Digital Pin 2
define Z_LIMIT_BIT 1 // MEGA2560 Digital Pin 1
#define Z_LIMIT_BIT     1 // MEGA2560 Digital Pin 1
Do you REALLY want to use one of the hardware serial pins (for Serial) for this purpose?
