Pin Mix Ups
Hi there. Ran into an issue I can’t figure out. Would appreciate any assistance possible. I have an Arduino Uno R3.
If I used up all of the Analog input pins from 0-5, can I use the Digital pins 0-5 along side the Analog? Or would I have to use 6-13 instead of 0-5 on the Digital side?
You can't use digital I/O pins as analog input pins, if that's what you are asking.
No my good sir. I meant, can I use both Analog pin 0 and Digital pin 0 at the same time?
Yes, you can use D0-D13,
and the analog pins as either D14-D19 or A0-A5.
