Pin Mode in IF statement
I can not get it to write the pump state to the LCD.
Code from line 79 should display the pump state.
//  Starting the pump sketch using seconds
#include <TimeLib.h>
#include <TimeAlarms.h>
#include <Wire.h>     //Arduino library
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
// Variables will change :
int RunningSeks;                              //Storing the Running Millis to seconds
int ReduceRunningBy = 0;                      // will store last time cycle was reset
int RunningLoop;                                // will store where in the loop we are
// Constants that won't change :
int OnInterval   =  150;                        // interval at which Pump is on 150
int LoopDuration = 3600;                        // interval at which Cycle will reset
const int PumpRelayPin = 7;                        // Pin to connect Relay to ORANGE wire
const int LightPin     = 8;                     //Wire to Light Relay YELLOW wire
    Serial.begin(9600);                      // initialize serial communication:
    pinMode      (LightPin , OUTPUT);
    pinMode      (PumpRelayPin , OUTPUT);
    digitalWrite (LightPin , HIGH);
    digitalWrite (PumpRelayPin , HIGH);
  setTime(16,57,0,2,10,19); // set time to Saturday 9:06:00am Jan 19 2019
        // *********************Defining the ALARMS*************************
        //  Alarm.alarmRepeat(20,45,0, LightsOn);  // every day
        //  Alarm.alarmRepeat(4,45,0,LightsOff);  // every day
        //  pinMode (LightPin, OUTPUT);
        lcd.init();                      // initialize the lcd
        lcd.backlight();
  }     //end setup
    RunningSeks  = (millis()/1000);
    RunningLoop = (RunningSeks - ReduceRunningBy);
    Serial.println(RunningLoop);
    lcd.setCursor(0,0);             //Firt set the cursor position, Second digit is always the line
    lcd.print("Loop =");
    lcd.setCursor(7,0);             //Firt set the cursor position, Second digit is always the line
    lcd.print(RunningLoop);
    lcd.setCursor(12,0);             //Firt set the cursor position, Second digit is always the line
    lcd.print("Sec");
    if(RunningLoop <= OnInterval)
        digitalWrite(PumpRelayPin, LOW);
        Serial.print("E & F Pump in ON     ");
        //Serial.println(RunningLoop);
      if((RunningLoop >= 170) && (RunningLoop < 770))     //turn other pump on 170  & 770
        Serial.println("Alarm: - Floating Raft Pump ON");
        digitalWrite(LightPin, LOW);
      if(RunningLoop >= 771)    // 771
        Serial.println("Alarm: - Floating Raft Pump OFF");
        digitalWrite(LightPin, HIGH);
      if((RunningLoop > OnInterval)&&(RunningLoop <= LoopDuration))
        digitalWrite(PumpRelayPin, HIGH);
        Serial.print("E & F Pump in OFF     ");
 if(RunningLoop > LoopDuration)
        Serial.print("***********************************Reset Loop *********************************************    ");
        ReduceRunningBy = RunningSeks;
digitalRead(PumpRelayPin);
if  (PumpRelayPin == LOW)
        lcd.setCursor(0,1);
        lcd.print("E&F On");
if  (PumpRelayPin == HIGH)
        lcd.setCursor(0,1);
        lcd.print("E&F OFF");
digitalRead(LightPin);
if  (LightPin == LOW)
        lcd.setCursor(0,10);
        lcd.print("F/Raft On");
if  (LightPin == HIGH)
        lcd.print("F/Raft OFF");
}                                 //***********************  End loop
  void LightsOn()                 // functions to be called when an alarm triggers:
   Serial.println("Alarm: - turn lights ON");
void LightsOff()
  Serial.println("Alarm: - turn lights OFF");
void digitalClockDisplay() {
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
void printDigits(int digits) {
  Serial.print(":");
  if (digits < 10)
    Serial.print('0');
  Serial.print(digits);
Line 79
This line reads the state of the pin then throws away the result
PumpRelayPin is set to 7. Will 7 ever equal LOW ?
Review the use of digitalRead() in the examples in the IDE
No, line #79 reads the value of the pumpRelayPin and then throws it away.
The next line then compares the pumpRelayPin (which is 7) to HIGH (which is 1) so they don't match.
Your code then repeats this with LOW.
You probably want:
  if ( digitalRead(PumpRelayPin) == LOW)
Also, all your variables that deal with millis() need to be unsigned long, not int
:o
Thanks, will try it tonight.
Will bother me the whole day as in my mind I am saying/doing the same just in 2 lines??
Why am I throwing the value away after reading the pin state?
You read the value but never assign the value to a variable.
Thanks
I think the light just came on. :grin:
