hi lads looking for a bit of advise hear. I keep getting errors hear. I was getting one saying that pins have no value. but that seams to be gone now. I cant seam to get rid of the error I have left witht he brackets. can any one help thanks
int pinOUT = 7;
int pinA = 8;
int pinB = 9;
pinMode(pinOUT,OUTPUT);
pinMode(pinA,INPUT);
pinMode(PinB,INPUT};
boolean pinAstate - digitalRead(pinA);
boolean pinBstate = digitalRead(pinB);
boolean pinOUTPUTstate;
// and
pinOUTstate = PinAstate & pinBstate;
digitalWrite(pinOUT,pinOUTstate);
my error reads
PinB was not declared in this scope
int pinOUT = 7;
int pinA = 8;
int pinB = 9;
} // end of setup
{ // dissassociated block starts here
pinMode(pinOUT, OUTPUT);
pinMode(pinA, INPUT);
pinMode(PinB, INPUT
}; // bracket followed by unnecessary semicolon
} // extra bracket
// and
digitalWrite(pinOUT, pinOUTstate);
Plus, your local variables declared in setup() will be destroyed once setup() ends, make them Global so that they can be used in loop().
thanks for the help. but I still cant get it to work. I am new to this programing so don't have much about it yet.
I changed the program around a bit and that has seam to got rid of the error I had. but now I am getting one that says pinOUT, pinA and pinB ware not declared in this scope.
int pinOUT = 7;
int pinA = 8;
int pinB = 9;
pinMode(PinB, INPUT);
Just a quick tip from one new user to another, C programming is completely case sensitive, so if you name something "PinA" in one part of your program you must use that EXACT name throughout the program. I haven't yet tested it but I believe you could have PinA, pinA, and Pina as separate names in the same function as long as they had all been declared in the Setup.
Kiwi_Bloke:
One good way I had of obfuscating BASIC programs after they had been developed and were ready for distribution, was to run the code through a program that changed the name of all variables into one word but with a mixture of upper case and lower case letters to make them different.
It was impossible to read the code but it ran just fine.
Grumpy_Mike:
"C Journal" or whatever name they changed to used to have "obfuscated code " contest.
Maybe this forum should have one once a while.
I suppose the contest entries would have to be enclosed in code quotes to qualify.
Bummer , that leaves me out.
Seriously - how about "sticky / or stickie ?" on most common C coding errors?
C / C++/ C# is case sensitive
C / C++/ C# commands terminate with semicolon ";"
Code without comments is like day without a sunshine
Code without comments may keep your job longer or very short.
Vaclav:
Code with incorrect comments is misleading
Code with comments that echo the code is utterly pointless
