Pin not declared
I am trying to control three servos with three buttons. I keep getting an error on my code concering my right pin, and I have not been able to troubleshoot the issue.
Here is the code:
#include <Servo.h>
Servo myservo; // create servo object to control a servo
Servo myservo2;
Servo myservo3;
int pos = 85; // variable to store the servo’s starting position
int pos2 = 85;
int pos3 = 85;
const int maxDeg = 165; // limits the maximum range of the servo’s movement to 165
const int minDeg = 5; // limits the minimum range of the servo’s movement to 5
const int movement = 2; // the amount to move the servo when the button is pushed. Value can be changed.
const int leftPin = 5; // tells the Arduino the location of the signal cable from the switch
const int middlePin = 6;
const int rightpin = 7;
const int outputPin = 8; // tells the Arduino the location of the signal cable to the servo
const int outputPin2 = 9;
const int outputPin3 = 10;
int leftPressed = 0; // variables we will use to keep information about the switch states
int middlePressed = 0;
int rightPressed = 0;
myservo.attach(outputPin); // left motor
myservo2.attach(outputPin2);
myservo3.attach(outputPin3);
// This code tells the Arduino to set the states of the pins to input mode
pinMode(leftPin, INPUT);
pinMode(middlePin, INPUT);
pinMode(rightPin, INPUT);
leftPressed = digitalRead(leftPin);
middlePressed = digitalRead(middlePin);
rightPressed = digitalRead(rightPin);
if(leftPressed) {
if(pos < maxDeg)
pos += movement;
myservo.write(pos); // tells the servo to go to the position stored in the variable ‘pos’
if(middlePressed) {
if(pos < maxDeg)
pos += movement;
if(rightPressed) {
if(pos < maxDeg)
pos += movement;
attempt_with_3.ino (1.9 KB)
rightpin != rightPin
Please remember to use code tags when posting code
Also, suggest you always use this format (even when there is only one line to execute):
if(........)
some stuff
Your almost there.
Use CTRL T to format your code.
Attach your sketch between code tags
[code]Paste your sketch here[/code]
#include <Servo.h>
Servo myservo2;
Servo myservo3;
int pos = 85; // variable to store the servo's starting position
int pos2 = 85;
int pos3 = 85;
const int maxDeg = 165; // limits the maximum range of the servo's movement to 165
const int minDeg = 5; // limits the minimum range of the servo's movement to 5
  if(leftPressed)
    if(pos < maxDeg)
    pos += movement;
     if(middlePressed)
    if(pos < maxDeg)
    pos += movement;
     if(rightPressed)
    if(pos < maxDeg)
    pos += movement;
But you have not corrected:
Did you want:
  if(leftPressed)
    if(pos < maxDeg)
    pos += movement;
    myservo.write(pos); // tells the servo to go to the position stored in the variable 'pos'
Or did you want:
if(leftPressed)
    if(pos < maxDeg)
    pos += movement;
From your second option, does this just isolate the input per pin?
I thought that pushing the bracket further would alter the void loop.
I fixed the code with "rightPin".
  if(leftPressed)
    if(pos < maxDeg)
    pos += movement;
Above is the same as:
if(leftPressed)
    if(pos < maxDeg)
    pos += movement;
which may or may not be what you want. :wink:
Which is different than:
if(leftPressed)
    if(pos < maxDeg)
    pos += movement;
