Hi all,
Heads up, i have never programmed before still very early days of learning
I am having some issues. I have a clock which is passing the hour as a variable.
Then i have digital pins connected to relays.
At its current form its a simple time clock .
My issue is the pins do not seem to lose voltage even though the code says they should of.
I can tell because the serial print stops writing with in the IF statement of any relay .
The pins get voltage when the time is right, but they do not turn off .
They remain on.
Any help will be greatly appreciated
#include <Wire.h>
#define RTC_Address 0x32 //RTC_Address
//Pin Connection
unsigned char date[7];
int hour;
int pin;
int pinout7 = 7;
int pinout8 = 8;
int pinout9 = 9;
int pinout10 = 10;
int pinout11 = 11;
int pinout12 = 12;
int pinout13 = 13;
String state = "OFF";
Wire.begin();
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(10, HIGH);
digitalWrite(11, HIGH);
digitalWrite(12, HIGH);
digitalWrite(13, HIGH);
I2CWriteDate();//Write the Real-time Clock
delay(100);
while(1)
I2CReadDate(); //Read the Real-time Clock
hour = Data_process();//Process the data;
Serial.print(hour);
// if (hour >=13 and hour <24 ){ // Turn on the lighting 1pm -12am
// pin = 7;
// pinaction(pin);
// Serial.print("Lights 1");
// Serial.println();
if (hour >=12 and hour <21 ) // Turn on the lighting Flowering 9am-9-pm
pin = 8;state = "ON";
pinaction(pin,state);
Serial.print(" Lights 2 are on");
if (hour >=8 and hour <9 || hour >=11 and hour <13 || hour >=14 and hour <22 ) // Turn on the Fan 2
pin = 9;state = "ON";
Serial.print("Fan2 is on ");
if (hour >=9 and hour <10 || hour >=13 and hour <14 ) // Turn on the co2
pin = 10;state = "ON";
Serial.print("Co2 is on morning dose");
if (hour >=9 and hour <22 ) // fan
pin = 11;state = "ON";
Serial.print("fan");
if (hour >=6 and hour <9 ||hour >=15 and hour <17 ) // Turn on the Air Pump
pin = 12;state = "ON";
Serial.print("Airation Active");
if (hour >=6 and hour <19 ||hour >=3 and hour <6 ) // Turn on light13
pin = 13;state = "ON";
Serial.print("Light 13");
delay(1000);//Delay 1 seccond
void pinaction(int a,String b){
boolean c;
if (b == "ON"){
c = LOW;
if (b == "OFF"){
c = HIGH;
// Serial.print("in the pin loop");
digitalWrite(a, c);
//Read the Real-time data register of SD2403
void I2CReadDate(void)
unsigned char n=0;
Wire.requestFrom(RTC_Address,7);
while(Wire.available())
date[n++]=Wire.read();
delayMicroseconds(1);
Wire.endTransmission();
//Write the Real-time data register of SD2403
void I2CWriteDate(void)
// WriteTimeOn();
// Wire.beginTransmission(RTC_Address);
// Wire.write(byte(0));//Set the address for writing
// Wire.write(0x01);//second:59
// Wire.write(0x37);//minute:1
// Wire.write(0x95);//hour:15:00(24-hour format)
// Wire.write(0x01);//weekday:Monday
// Wire.write(0x19);//day:19th
// Wire.write(0x10);//month:October
// Wire.write(0x15);//year:2015
// Wire.endTransmission();
// Wire.write(0x12); //Set the address for writing
// WriteTimeOff();
//The program for allowing to write to SD2400
void WriteTimeOn(void)
Wire.write(0x10);//Set the address for writing as 10H
Wire.write(0x80);//Set WRTC1=1
Wire.write(0x0F);//Set the address for writing as OFH
Wire.write(0x84);//Set WRTC2=1,WRTC3=1
//The program for forbidding writing to SD2400
void WriteTimeOff(void)
Wire.write(0x0F); //Set the address for writing as OFH
Wire.write(byte(0));//Set WRTC2=0,WRTC3=0
Wire.write(byte(0));//Set WRTC1=0
//Process the time_data
int Data_process(void)
unsigned int i;
for(i=0;i<7;i++)
if(i!=2)
date[i]=(((date[i]&0xf0)>>4)*10)+(date[i]&0x0f);
date[2]=(date[2]&0x7f);
date[2]=(((date[2]&0xf0)>>4)*10)+(date[2]&0x0f);
//Use the serial monitor to see information being transmitted
Serial.print("Sec = ");//second
Serial.print(date[0]);
Serial.print(" Min = ");//minute
Serial.print(date[1]);
Serial.print(" H = ");//hour
Serial.print(date[2]);
Serial.print(" W = ");//week
Serial.print(date[3]);
Serial.print(" D = ");//day
Serial.print(date[4]);
Serial.print(" M = ");//month
Serial.print(date[5]);
Serial.print(" Y = ");//year
Serial.print(date[6]);
hour = int(date[2]);
return hour;
