Hi
I have a 1.8 TFT display st7735 from Joy-it where pin is VCC, GND, SCL, SDA, RS / DC, RES and CS
But the setup I want to build is pin like RST, CS, D / C, DIN, CLK, VCC, BL, GND
VCC and GND are the same on both.
But what about the rest?
Hi
Hi Henrik_t7,
Did you actually build the assembly according to the revised schematic on the hackster website, using identical parts and the sketch suppied ? Did it work? If yes, then it is interesting to hear what made you decide to post your question
On my display are pin names that I write in the forum, but on the dirgram on the hackster website other pins are written on the same 1.8 display.
How do I connect my display to this dirgram, on the hackster website.
I haven't built it yet because I don't know if it's the same pin connection on the display.
Thanks
It is always wise to post a link to the actual display that you bought. e.g. Ebay sale page.
Then you get an accurate reply.
You have :
VCC,
GND,
SCL = CLK,
SDA = DIN,
RS / DC = D/C,
RES = RST,
CS
If there is no BL pin, ignore it. (the backlight is permanently on)
David.
Thanks
