Hi , if you use mkrgps not stacked but connected via the 4 wire cable provided to a mkrgsm what are the pin used?
i need to know because i need to setup all the pin not used in input_pullup to reduce power consumption
Hi @tradexsrl. The pinout for the connector is shown in this diagram:
You can see it uses the SDA and SCL pins of the I2C interface. The Arduino pin numbers of these pins are 11 and 12.
hi , thank's found it , a doubt: it use also the pa21 which is D7 ?
That's correct. This is the "EXTINT" pin mentioned in the MKR GPS pinout table:
