My project controls power to an Arduino with a tilt switch, timer and an N-channel Mosfet as a switch.
When the power is off the Arduino is floating with no connection to ground. (Arduino ground is switched through the Mosfet).
The arduino itself is configured to control a different Mosfet to fire a solenoid through an output pin with a 10k pull down resistor. (Pulled to external ground not to the switched ground).
Everything works as expected when the arduino is on. However, when the arduino power is cut by the timer, and the arduino is "floating", the output pin seems no longer to pulled to ground by the 10k resitor and it goes high.
Is this avoidable with the configuration I have? If not - I presume the only solution is to switch the Arduino with a P channel Mosfet on the positive and have it permanently connected to Ground ?
sjdevlin:
You should pull down to Arduino ground only - otherwise you are pushing current through the protection
diodes on the chip (generally not a great idea).
The Arduino pin is at Vcc when the Arduino isn't powered, so all its pins will be at best 0.5V below Vcc, hence
your problem.
High side switching would have been less problematic.
