Pinball Project
I hate it. Now I stripped down everything to pin11=output, pin12=input(pullup), and pin13 as LED output (using only the built in LED).
On pin11 I sent a 1Hz signal; 500ms low and 500ms high. Pin13 displays the reading from pin12. Everything else is completely unplugged.
Now, with nothing conneted to the board, the LED stays lit all the time. Just as it should.
With a diode connected from pin12 to pin11, the LED flashes at 1Hz. Just like it should.
But with pin12 and pin11 connected to an open circuit on the playfield - totally open, not even several megaohms - the LED flashed occationally. I don't even touch the machine, and like I said, nothing else is plugged in.
What can it be? The only thing I can think of, is that the quite long parallell wires become some kind of capacitor that discharges or something. Or the unshielded wires make some kind of hum like the one you can hear from a microphone line that's lost its ground shield.
Any suggestions I may try? Some kind of software or hardware filter? Some more puul-up? Or pull-down?
I found a potential solution. In my desperation, I thought that maybe the little transience when wires connected pin11 goes from high to low could effect the wires connected to pin12. So, as much as you all discourage delays, I added a one ms delay between writing to pin11 and reading pin12. And yes, it seems like it made the trick. At least in this very stripped off test.
  digitalWrite(11, HIGH);
  delay(1);
  if(digitalRead(12) == LOW)
    digitalWrite(13, LOW);
    digitalWrite(13, HIGH);
This time, the LED only flashes when the switch is closed, just as I excpected.
Well, that's all for tonight. Tomorrow I hopefully will get the time to test this scanning the whole switch matrix.
EDIT: The downside of this solution (if it even works) is that it adds 6 milliseconds to every complete switch matrix scan performed.
Post the whole sketch - the one you had where it "triggered" even though the switch was open. The fragment you showed gives no clue why it should flash, even though that is what you wanted/expected. So there may be other things "lurking".
An Arduino input pin is High Impedance, meaning that a long attached wire (and no defined voltages) results in "random input". So you must have a pullup or down, and the closing of the switch pulls it in the opposite direction.
Ok, here's the erratic code:
  pinMode(11, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(12, INPUT_PULLUP);
  digitalWrite(11, LOW);
When pin11 is LOW, that "line" of switches is scanned. When HIGH, another line of switches is scanned. (In this test sketch, I have stripped off all other lines and use just one switch to isolate the problem.) And the problem was that even though pin12 wasn't connected to a switch closed to LOW and it was pulled up, it still returned LOW occationally.
But here's the working code:
  delay(1);
  delay(1);
The only difference is the two "delay(1);" lines. It seems one millisecond is enough to settle down the induction or whatever that pin11 may have caused while going LOW.
Next step is to see if it still works when I remove the "delay(500);" lines. But I can't do that tonight, I'm busy with other stuff.
OK, let me paraphrase your situation. You have 4 combinations and have only reported on two.
You send a signal from pin11 to pin12, and use pin13/LED to verify it comes through. This works if the connection is very close (Why did you use a diode? What do you think happens if you reverse the diode? I think it will "fail"). You do not say if things work as expected if you do not connect the two.
This fails if you have long wires which go "somewhere", claiming there is a connection although your Ohm meter says they have no connection. (Somewhere is a switch matrix, or circuit or ?) Does it work as expected if the switchmatrix-circuit-whatever is closed?
The observation that if you wait "delay(1)" between setting pin 11 and sampling it on pin 12, it yields correct result (you only say on the open, not the closed state). Have you tried delayMicroseconds(100), (50), .. (four is the minimum)? You code without the delay will turn the pin on and sample it on/off the other approximatly 300-500 nanoseconds later (I have not worked out the precise timing) or 15 meters at lightspeed. Any capacitance/inductance will drastically reduce the speed. The pinball components work in deci or centiseconds for most stuff. Your Arduino is working in sub-microseconds.
Lastly what makes it "scan one set of switches on LOW and another on HIGH"? A circuit? Diode? Relay?
Good luck on the continuing bug-hunt :wink:
Thanks. I hope we solved it with that delay.
Sorry. With nothing connected, the LED doesn't blink. Just as expected. With the pinball wires connected and the switch closed, it blinks as expected. At least when it's the first switch to be tested. If not, the first switch which is open sometimes yields a "closed".
The reason I used a diode is because there has to be a diode connected in series with every switch in the matrix, or else the matrix will let through false positives. And I wanted to simulate the connection as faithful to the original as possible. I didn't believe it, but I though that maybe, maybe the voltage loss over the diode would be enough to keep the input of pin12 HIGH.
A reversed diode on the stripped down test will only lead to fail to let the signals through form pin11 to pin12.
A reversed diode in the switch matrix would lead to both fail to let through the correct signals and let false signals go to backwards through a closed switch and thus yield false positives while testing some of the other switches in the matrix.
No, that's a new keyword for me. I will keep it in mind for the final fine-tuning.
Wow! That's totally amazing. Really hard to believe. (But of course I do believe you!)
Originally, it was a 7445 BCD To Decimal Decoder. But it is fried, so I built a new multiplexer. While hunting the bugs, I even skipped that one to eliminate potential error sources. (The bug persisted anyway, because it appears to be due to the long wires in combination with the speed of the Arduino.) But I just decided to skip the home-made multiplexer anyway; the Arduino Mega will have more than enough pins to handle that multiplexing itself.
Thanks again for all the input, hints and encuoragement.
/SimLego
Yes, it works now! I tested with 5 switches from two different lines, the pin13 LED indicated in just the expected patterns for the different inputs. Even though I haven't tried input from all switches, I strongly believe it will not add any big problems.
So, my work plan looks something like this:
  1. Interacting with the playfield.
    1a. Input from the Switch Matrix - check!
    1b. Output to Bonus Lamps.
    1c. Output to other Lamps.
    1d. Output to Solenoids.
  2. Top Box.
    2a. Output to Ball in Play, Tilt, and Game Over Lamps.
    2b. Output to Free Game Number LEDs.
    2c. Output to Score Table. (That will be the by far most diffucult task.)
    2d. Keeping High Score somehow.
  3. Cabinet.
    3a. Input from Tilt, Slam Tilt, Door, Play Switches. (more?)
    3b. Output to In Play Relay.
    3c. Sound Effects.
    3d. (Mostly Playfield, but I put it here) A Startup Sequence for the lamps would be cool. And Display Mode.
    3e(?) Maybe some reset or at least inhibit coils during startup. If needed.
I wonder what year this project will be finished...
Driver card modified/fixed. Took me all day. Hopefully I will not have to remove it again for a long time.
Time for a coffee, and then back to programming the Arduino.
There we go. All is set. Will it work? (Probably not...) I'll keep you informed.
Update: Most of the features work, after I corrected a fatal mistake that cost two digital input pins on my Mega.
It may have caused more damage, since there are two strange minor misbehaviours that are really hard to explain.
After frying four or more input pins, I decided to use a 74LS08 as a quad buffer for the inputs, in an IC socket so it's easily replaced. (I have got plenty of 7408's but only one Arduino Mega...) Don't know why the Arduino inputs were fried, I see no reason, don't know why the 74LS08 can (at least so far) take those blows...
But at least it works now. Finally I'm done with the interfacing to the playfield. Everything works just as I programmed it to do, although it's much more of "debug mode" than playable rules. Programming the rules will be the easiest part I guess, apart from I have to guess a lot of the gameplan.
I don't know if you would have any interest in watching a video clip using my very cheap digital camera. It's not even a video cam, just an ordinary camera with some video fuctions. I could do that if anyone's interested.
SimLego
Thats what the "Exhibition / Gallery" forum group is for :slight_smile:
Thats what the "Exhibition / Gallery" forum group is for smiley
Good to know, before I trespass some more conventions. :slight_smile:
Not quite so stuffy in here anymore, now that I replaced the Master Unit board with an Arduino. :smiley:
hello,
I start a pinball project also with an MEGA2560 for replace a system1 generation board.
I have write a code for the switch matrix.(8x5 sw). 8 Inputs. 5 Ouputs
I plan to use BCD decoder for the display 7 segments. i search for the refresh frequency. 17 Outputs (or 24 outputs max without NAND i need to find a solution for rêplace NAND with the dbs signal).
For solenoids i use the original driver board. 8 outputs.
for lamps 4+ 4 BCD Outputs with 74154 for 9 lines (with flip flop on the driver board)
46 I/O
i begin to write code step by step for validate each functions
regards.
Cool, chris91!
I assume you are talking about Gottlieb's System 1, since I believe Recel went straight to "System 3" for unknown reasons. It would be interesting to know the name of the game you are reviving.
For most functions, I found it much easier to repair (where needed) the existing boards, rather than making new. However, some areas of the Driver/Multiplexer Board of my Crazy Race machine was so burnt that I let Arduino handle the multiplexing and made a new Lamp Driver "Add-On" Board for the bonus lamps.
But I repaired the control board for the 7 segment displays by replacing 2 fried 7475's and then I imitated the signals from the totally destroyed CPU Board, step by step just like you. To generate a refresh frequency matching my machine, I inserted a 150 microseconds delay before each strobe (two digits displayed at each strobe) and then activated for 700 microseconds:
    delayMicroseconds(150);
    digitalWrite(X[i_strobe], HIGH);
    delayMicroseconds(700);
    digitalWrite(X[i_strobe], LOW);
Please note that if you have another system, you probably will have to use different delays. Also note that my approach requires two Arduinos; one for the playfield and one dedicated to control the top box.
I put 1N4148 diodes between the Arduino and solenoid drivers, just in case one of the driver transistors would break down and short, and send 40 volts back to the output pins of the Arduino. I don't know if this will help, but at least it makes me feel a bit better. :slight_smile:
Good luck with your project, chris91! Please let me know of its progress.
Snyggt jobbat SimLego :slight_smile:
I've been checking your progress from time to time.
SimLego:
To me that sounds like a good place to use some opto-isolators.
SimLego:
Cool, chris91!
I put 1N4148 diodes between the Arduino and solenoid drivers, just in case one of the driver transistors would break down and short, and send 40 volts back to the output pins of the Arduino. I don't know if this will help, but at least it makes me feel a bit better. :)
Thanks for your help.
With the AT2560 and 54 I/O Line only one chip is needed if some signals are multiplexed like on the original board (Lamps with 74154, 7 segments display with 7448). Adding a 74154 for the stobe on 7 segments safe 12 Outputs (not like the original with lot of NAND gates)
My idea is to use a original Gottlieb cpu board, unmount dead Rockwell chips and wiring the arduino I/O at the place.
I plan to rewrite the TORCH or SOLAR RIDE program. My solar ride system1 board is ok so easy to check and test all the situation with the original program. My Torch board is dead, but i can replace the cpu by other for testing the original prom program. after that i have also the Countdown. Why not implement all models in the second time. of course if the first is a success.
I receive my arduino on few days and waiting for experiment each parts of program
I must structured the main loop. I think use timer for switch matrix reading and multiplexing output writing for 7 segments display.
For the 1N4148 on the output line it's correct. Gottlieb released first Driver board generation with this solution. also with old drivers board it's the first think to make for protect the CPU board. However, some 7417 (inverter) are present between the output and the driver transistor on original board.
regards
