PinButtonEvents - Library for handling button events with various conditions and debouncing support
This library provides a versatile class for handling button events, including press, release, hold, and repeated presses, with support for debouncing and a vast number of combinations. It allows you to define multiple callbacks for different button states, hold durations, and repeated press counts, enabling the implementation of complex button-driven functionality with ease.
you should not rely on the constructor to set the pin mode. When you define a global variable, the constructor is called before main() is called and main() could reset the pin status to something else (for example it would fail on Nano ESP32 - the oneButton library has the same issue)
ideally you would add a begin() method to call from the setup() and that's where the pinMode would actually be set
Good point, thanks I’ll make it work that way
Added sequences in version 1.0.2, now, you can use something like Morse Code to trigger events. We can create a password mechanism with just one button!
